V ID says one volt but Vcore says 1.7 there.
Test the memory / cache properly man! This is all terribly lax lol.
Test the memory / cache properly man! This is all terribly lax lol. Seems like a very nice chip though.
Ps. Don't run HW monitor along side AI suite or you're just going to get polling errors, the readings will mean nothing dude
Ok, you shouldn't use more than one polling software
Lol that's the point they may well not if you run both together![]()
Hi guys,
Having some issues with AI Suite 3. I've abandoned it for any overclocking but i still like it for fan control. I had the "turbo app" set up such that it would switch from quiet preset to turbo preset upon launching bf4.exe. For whatever reason, this has stopped working.
I have set the power option to "auto" as per the instructions. It says turbo app "on", "activated setting for --". If i attempt to create any instruction for any .exe and it never does anything.
Prior to manual overclocking this worked fine. Is there some setting in the bios that will overriding this?
Your problems are not after the PC has woken from sleep is it ?
Not tried presets, but I am having problems with Q-fan and sleep.
After the PC has woken from sleep, It spins them up to 100% and you cant do anything with them till you reboot.
What motherboard are you using ?
Whats safe vcore and load temps on 5930K?
cheers
So you got it rigged up then mate?
Thoughts/regrets?![]()
No regrets...Flogged my my 5650 tonight..mobo and 6gb ram sold.. and just working upgrade cost out...
Will be around £345 outlay so no regrets....as money was going out...money was coming in...
Its nice to have a new rig TBH...Ran some benchies at stock to compare and its been a nice little upgrade....
SSD working at full belt etc...
I guess I was lucky...got a good deal in MM....
All good then mate. Well I'm gonna upgrade as well pretty soon. My X58 rig runs so well though not sure I want to sell it to be honest as the chip is such a nice one. It would make a really nice swap for my current hackintosh rig I have so I think that's what's gonna be done. So the outlay will be quite a bit more than you but ain't that bothered as it all goes down as a business expense.![]()
YOLO![]()
