Quick run
780Ti 1240/1840
4790k 4.8
347.09 drivers.
1080p
1440p
Don't forget to post the detailed settings for the scoreboard.
Quick run
780Ti 1240/1840
4790k 4.8
347.09 drivers.
1080p
1440p
My bad, I'll add them tomorrow night.
Updated post 40 with the detailed settings![]()
I think I posted 2 from when i first installed the game, doh![]()
May as well dethrone you before your new cards arrive Kaap.
Will have another go and overclock at some point.
5960X @4Ghz
4x290X @1000/1375Mhz
2160P
15.3 Beta
Do you have the settings text file as well please.![]()
5960X @4Ghz
2160P
15.3 Beta
. A good sign of things to come it seems.That's a nice jump from your last score.
I thought you meant beating Kaap's quad 290 score, not 980s. A good sign of things to come it seems.
As promised.
5960x @ 4.9Ghz
4x290X @ 1010/1375Mhz
15.3
<?xml version="1.0" encoding="UTF-8" ?>
<!-- Benchmark Mode Results -->
<benchmark directx11_feature_level="11.0" instruction_set="AVX" author="AMDMatt" date="07:13:27 on 19/03/2015" machine="Matt">
<totals races="1" total_time="00:02:34" total_race_time="00:02:27" race_time="00:02:27" />
<fps_race min_fps="119.403252" max_fps="183.609085" av_fps="149.527313" min_fps_ms="8.374981" max_fps_ms="5.446353" av_fps_ms="6.687741" />
<fps_total min_fps="119.403252" max_fps="183.609085" av_fps="149.527313" min_fps_ms="8.374981" max_fps_ms="5.446353" av_fps_ms="6.687741" />
<track index="1" numInRotation="1" totalProfiled="1">
<results samples="22032" min_fps="119.403252" max_fps="183.609085" av_fps="149.527313" min_fps_ms="8.374981" max_fps_ms="5.446353" av_fps_ms="6.687741" battery_percentage_used="0" />
<settings name="san_francisco" route="route_0">
<car name="sls" livery="user" />
<car name="320" livery="06" />
<car name="sls" livery="04" />
<car name="320" livery="user" />
<car name="sls" livery="08" />
<car name="g40" livery="user" />
<car name="sls" livery="03" />
<car name="320" livery="01" />
</settings>
</track>
<hardware_settings_config version="21" deviceId="0x67B0">
<cpu>
<threadStrategy workerMapFile="system/workerMap8Core.xml" forceFeedbackProcessor="6" dvdStorageProcessor="7" dataSetMonitorProcessor="4" renderProcessor="0" updateProcessor="2" fileStreamProcessor="5" />
</cpu>
<audio_card>
<dynamic_range value="high" />
<eq value="flat" />
<voice_chat enabled="true" />
<push_to_talk enabled="false" />
<ai_count value="high" />
<voice_count value="high" />
</audio_card>
<graphics_card firstBoot="true" rating="4">
<directx forcedx10="false" />
<eyefinity force="" osd="" />
<stereo enabled="false" separation="0.015" convergence="0.5" />
<advanced forward="true" global_illumination="true" />
<intel tree_aoit="false" particle_avsm="false" />
<resolution width="3840" height="2160" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
<refreshRate rate="60" />
</resolution>
<gamma level="0.8" />
<avsm enabled="true" />
</graphics_card>
<shadows enabled="true" size="4096" maskQuality="2" particles="true" />
<advanced_fog enabled="true" />
<particles enabled="true" wind="true" dynamicRes="false" lowResScalar="2" nearFadeBias="0" />
<crowd enabled="true" detail="4" />
<cloth enabled="true" />
<groundcover mode="ultra" clutter="true" />
<objects lod="1.5" maxlod="0" />
<trees lod="3.0" maxlod="0" meshes="true" meshes_in_all_passes="true" />
<vehicles characterQuality="4" lodQuality="3" />
<track quality="2" />
<envmap faces="6" size="1024" drawallobjects="true" scaleminsize="0.1" mindistance="200.0" />
<water update="true" detail="3" scale="2" drawallobjects="true" tessellation="true" />
<mirrors enabled="true" width="1024" height="256" car_maxlod="0" />
<skidmarks enabled="true" />
<dynamic_ambient_occ enabled="true" quality="3" />
<dynamic_ambient_occ_soft enabled="true" />
<night_lighting volumes="true" lights="0" shadows="true" onlyHeadlights="false" shadowSize="2048" />
<textures resolution="2" />
<shaders quality="2" low_quality="false" />
<anisotropic min="4" max="16" />
<physics environmentalDamage="true" vehicleDamage="true" />
<input device_type="auto" />
<motion enabled="true" ip="dbox" port="20777" delay="1" extradata="0" />
<second_screen quality="2" />
<oculus enabled="true" headMovement="true" chromatic="true" timeWarp="true" vignette="true" overdrive="true" convergence="1.0" />
</hardware_settings_config>
</benchmark>
