Coming from an X58 and old skool bios this Gigabtyte Gaming 5 bios is crazy! lol![]()
Noticing any difference in speed over the Xeon?
Us Xeon owners are all itching to know!![]()
whats everyone using to stress test?
read that small FFT should be avoided?
Whats the average vcore needed for 4ghz? 5930K
and
whats the average for 4.5ghz?
cheers
Asus don't recommend Prime95 so for that reason I don't bother with it.
RealBench is what I've used.
Hi guys,
Having some issues with AI Suite 3. I've abandoned it for any overclocking but i still like it for fan control. I had the "turbo app" set up such that it would switch from quiet preset to turbo preset upon launching bf4.exe. For whatever reason, this has stopped working.
I have set the power option to "auto" as per the instructions. It says turbo app "on", "activated setting for --". If i attempt to create any instruction for any .exe and it never does anything.
Prior to manual overclocking this worked fine. Is there some setting in the bios that will overriding this?
Would someone mind posting their of settings using a gigabyte bios....I have changed all the values I think...but it's still not booting at 4ghz....it's something obvious but I can't see it lol
Are most people using the 125 strap?
125 strap for 3000 memory only.
Make sure to set the cpu input voltage to 1.9
