- 4 Oct 2011
- Newbury, UK
Don't get my you would want Windows 10 to look like an aging dinosaur that is XP
Brave people sticking in on a main machine. Remember that it's effectively late Alpha software so don't start crying when you lose data or something doesn't work as it does under 8.1.
I'll stick to a virtual machine thanks very much!
The start menu thing is annoying but it still works.
Don't get my you would want Windows 10 to look like an aging dinosaur that is XP![]()
Check out my post above.![]()
I'm really not a fan of "Search the web and windows" bar. Especially since Cortana's not available.
"Hey guys, check out Cortana in the new build. Unless you're in the UK, then LOL".
Is the Xbox One to PC Streaming capability about yet?
Windows 8.1 to me is still the best OS I've used.
Cheers so thats a built in option in Win 10? If so cheers no need to worry then
Win 10 with all the classic options will do me.
Installed it the other day, loving so far, however I'm using build 9841, and I have tried updating it using the PC Settings, Updates and Preview section, but I seem to be getting nowhere as it isn't updating it.
Has it downloaded the update?
It wouldn't let me the other day, but a quick restart and it d/loaded, but was a bit slow.
Right click task bar -> search bar -> Disable or show icon instead of box.
Download the ISO for 9879 from this link.N17
Nope, it says on the Preview Builds that it is downloading, but the bit on the right is just spinning round, next to where it says Downloading New Preview.
