Caporegime
- 8 Jul 2003
- In a house
Feels like its been centuries since we had a driver update lol
Its only been about a month odd
Matt, it seems that the Crossfire profile on the 280X for Catzilla is not working. Had to force a custom profile to get it working.
Hi Matt, any chance of some SWTOR attention?
There's been a memory leak like this on and off for the HD5 series since BF3. Was always fixed, then broken then fixed then broken etc. BF4 however never got fixed, although last time I played I didn't actually get the leak. Occurs only on map change though not all the time, always consumes ram like the cookie monster eats cookies, and of course since W8 does a hybrid shutdown you need to either do a full shutdown or a restart to clear it.
What do you mean?
Crossfire doesn't work in the game, hasn't for a long time. I am unsure if it's a game issue or driver issue, but a lot of people with AMD cards have said it's not worked properly for well over a year.
I'm aware the game uses crap code so it may not be the drivers fault, but if there's any optimisation that can be done it would be greatly appreciated.
Duly noted will investigate as it's not a game I'm familiar with.
Matt, any word yet on whether we're getting a fix anytime soon for sound crackling (DPC latency issues, really) with CF + Vsync on + multiple monitors? Either vsync off, or turning extra monitors off is still the only real solution. (Though I've found a much less annoying workaround for now by putting my 2nd monitor on the iGPU instead).
Can you setup your trust account so i can send you an email please.
Does xfire not work for Wolfe stein the new world order?
Hi Matt, I'm having a weird issue with a couple of games and would love some advice. I was playing assetto corsa (there are a few others but I can't remember which just yet) and while both 290s were under full 99% load, my 2nd gpu just sits at idle clocks. I disabled ULPS, which then meant it sat at 300mhz, which was the new idle clock anyway. So before I start mucking about uninstalling drivers etc, is there anything obvious I should try?
Still stuck dealing with that DPC latency issue as well. Reported it yonks ago, and it's getting really frustrating having to disable my 2nd monitor every time I want to play a game :/
AC is well known for not supporting xfire.
Try some of the stuff in this thread, but don't get your hopes up too much for it to cover all bases.
All of these fixes seem to work great in hotlap/practice, yet as soon as you chuck in a bunch of AI or other players, your usage will drop.
I did have some success with the Radeon Pro solution though (in conjunction with the BF4 profile) and have it running all three cards with everything maxed out, 8xAA set in the ini and VSR @3200x1800 with a full grid of cars at a pretty steady 70fps or so. Could and should be better, but hey...
YMMV and good luck
Apparently, AMD don't see the matter as being urgent enough or AC as being popular enough to warrant their attention for a proper xfire profile.
To be fair, given the way that most of the in game apps break xfire, I can see it being a right pain to implement.
Is there anything you can do about Rome 2 Matt? No matter what settings I change my 290x in CF won't run 100%. In fact, whatever settings I change, something different always happens. Don't know if you can help me here
