** SOME GREAT DEALS ON AMD GRAPHICS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK we've got some stonking deals on AMD cards, check them out:
XFX AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory Speed: 5000Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 2yr
Was [£529.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
Asus Radeon R9 290 DirectCU II OC 4096MB GDDR5 PCI-Express Graphics Card @ £229.99 inc VAT
Get ready for Half Life 3 and GTA V PC Launch with an AMD Radeon 290 from Asus in the form of this DirectCU II OC graphics card, overclocked out the box and rewarded by our own Gibbo as one of the best cooled and quietest 290's on the market, this is a card for anyone looking to play the latest or future titles to come.
ASUS, leading provider of high-performance graphics solutions, is now introducing the ASUS R9290-DC2OC-4GD5 which features 4GB GDDR5 memory on board and supports DirectX®11.2 and OpenGL®4.4. ASUS exclusive DirectCU II thermal with fansink and flatten copper heat-pipes directly contact with the GPU delivers 20% cooler and 3X quieter performance. DIGI+ VRM with Super Alloy Power delivers precise digital power for superior efficiency, reliability, and performance. In addition to solid hardware specification, ASUS exclusive GPU Tweak utility helps you to modify and monitor clock speed, fan performance and more, all via an intuitive interface. What's more, a simple online-streaming function lets you share gameplay live - so people can watch as you play!
R9290-DC2OC-4GD5 with all these eye-catching features now offers users all over the world a chance to experience a stunning gaming environment!
Specification:-
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- ROPS: 64
- Core Speed: 1000MHz
- Memory Speed: 5040Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Was [£239.99] Inc. VAT
Only £229.99 inc VAT.
ORDER NOW
Asus Radeon R9 290X DirectCU II OC 4096MB GDDR5 PCI-Express Graphics Card @ £289.99 inc VAT
The new card benefits from exclusive ASUS GPU Tweak, an easy-to-use tuning tool for instant performance boosts, 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions, and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and bring in-game audio to life with more accurate environmental sounds.
The new ASUS R9 290X has a unique advantage in the shape of GPU Tweak, an exclusive ASUS tool that helps users to squeeze every last drop of performance out of the Radeon R9 290X GPU. This includes the ability to control finely GPU and video-memory clock speeds and voltages, cooling-fan speeds and power-consumption thresholds - so overclocking is both made easy and can be carried out with high confidence.
R9 290X is equipped with 4GB of high-speed GDDR5 memory, allowing gamers to push their favorite titles much further by upping in-game visuals to maximum resolutions. The new card also includes AMD Eyefinity technology to broaden the gaming landscape, so gamers can expand the playing field across up to six independent displays, via DisplayPort or DVI.
Specification:-
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1050MHz
- Memory Speed: 5400Mhz
- Warranty: 3yr
Was [£299.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
MSI Radeon R9 290 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £229.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290</b> <br />
- Backplate included: Yes <br />
- GPU: Hawaii Pro <br />
- Litecoin Hash Rate: 800-950 <br />
- Stream Processors: 2560 <br />
- Core Speed: 977MHz <br />
- Memory Speed: 5000Mhz <br />
- Memory interface: 512-Bit <br />
- Memory capacity: 4096MB GDDR5 <br />
- Cooling: MSI Twin FrozR Gaming <br />
- PCI-Express X16 lane required <br />
- 600W or greater PSU required <br />
- Power Connectors: 8-pin + 6-pin required <br />
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort <br />
- Warranty: 3yr
ORDER NOW
MSI Radeon R9 290X Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £269.99 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290X</b> <br />
- GPU: Hawaii XT <br />
- Litecoin Hash Rate: 850-1000 <br />
- Stream Processors: 2816 <br />
- ROPS: 64 <br />
- Core Speed: 1040MHz <br />
- Cooling: MSI Twin FrozR Gaming Cooling <br />
- Warranty: 3yr
Was [£289.99] Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
MSI Radeon R9 290X Gaming Edition 8192MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
Specification:
- ROPS: 64 <br />
- Memory capacity: 8192MB GDDR5 <br />
- Warranty: 3yr
Was [£329.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
MSI Radeon R9 290X LE Lightning Edition 4096MB GDDR5 PCI-Express Graphics Card @ £289.99 inc VAT
The MSI R9 290X Lightning is a genuine contender as a powerful gaming card. Not quantified by "for a Radeon", this thing is fast, full stop. Easy, and rewarding to overclock with a fantastic cooler and every option you could want. It's Brilliant. It's Rapid. It's Yellow. It's a worthy winner of our OC3D Gold Award and the best Radeon card on the market today.
Features:-
- Triple Level Signals: Show the real time GPU load by different colours
- TriFrozr Thermal Design: Triple PWM fans with independent control system on
- Pure Digital PWM Control: Digitally controlled GPU, Memory and VDDC.
- Twin BIOS: Seperated BIOS chips for regular use and LN2 overclocking.
- Enhanced Power: 12 GPU phases and 3 memory phases on a custom designed 12 layers PCB for amazing overclocking potential.
- Military Class 4 Components pass MIL-STD-810G certificatiomn for best stability and quality.
- Equipped with CopperMOS, Hi-C CAPS, New SFC and All Dark Solid CAPs.
- Triple Overvoltage: Total control with GPU, Memory and PLL voltage adjustment.
- Triple Temp Monitor: Real time monitoring of GPU, Memory and PLL Conditions.
- V-Check point: For direct and accurate read-out of GPU, memory and PLL voltage.
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1030MHz
- Memory Speed: 5000Mhz (Samsung IC)
- 750W or greater PSU required
- Power Connectors: 2x 8-pin + 1x 6-pin required
- Warranty: 3yr
- Download PDF Presentation: https://www.dropbox.com/s/9kkxjuw2a0n421v/R9 290X LIGHTNING Infokit 1_0 - PDF Version.pdf
ORDER NOW
Powercolor Radeon R9 290X PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card @ £269.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1050MHz core and 5400MHz memory.
Specification:
- Radeon R9 290X
- Coil Whine Reduction Technology (Exclusive to Powercolor)<br />
- ROPS: 64 <br />
- Core Speed: 1050MHz <br />
- Memory Speed: 5400Mhz <br />
- Cooling: 2-Slot Blower Fan <br />
- 750W or greater PSU required <br />
- Comes with BF4 Voucher included in the box <br />
- Warranty: 2yr
Was [£275.99] Inc. VAT
ORDER NOW
Powercolor Radeon R9 290X PCS+ OC 8192MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** @ £311.99 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 8GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- ROPS: 64 <br />
- Core Speed: 1030MHz <br />
- Memory Speed: 5500Mhz <br />
- Warranty: 2yr
Was [£319.99] Inc. VAT
Only £311.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290 Tri-X OC 4096MB GDDR5 PCI-Express Graphics Card (11227-00-40G) @ £229.99 inc VAT
Specification:
- Core Speed: 1000MHz <br />
- Memory Speed: 5200Mhz <br />
- Warranty: 2yr
Was [£249.95] Inc. VAT
ORDER NOW
Sapphire Radeon R9 290 Vapor-X OC 4096MB GDDR5 PCI-Express Graphics Card (11227-04-40G) @ £239.99 inc VAT
Sapphires 290 Vapor-X is the fastest 290 on the market with a core clock of 1050MHz but even more impressive is the 5600MHz memory clock and with 4GB of RAM making this card perfect for 4K resolution and latest games such as Titanfall, Diablo 3 etc.
The Vapor-X cooler is simply the best cooler available full stop on any 290 card, it operates in near silence but has incredibly powerful cooling ability making this a great card for both gamers and overclockers.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Memory Speed: 5600Mhz
- Power Connectors: 2x 8-pin required
- Warranty: 2yr
- Kitguru Review: http://www.kitguru.net/components/g...280x-vapor-x-oc-and-r9-290-vapor-x-oc-review/
Was [£259.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290X Vapor-X 4096MB GDDR5 PCI-Express Graphics Card (11226-10-40G) @ £289.99 inc VAT
The SAPPHIRE R9 290X Vapor-X OC features several of the company’s industry-leading technologies and a factory overclock to deliver best in class performance with very low noise.
Based on the award-winning Graphics Core Next (GCN) architecture from AMD with 2816 Stream Processors, the SAPPHIRE R9 290X Vapor-X is an Overclocked edition which boasts 4GB of the latest GDDR5 memory running at 1410 MHz (5.64GB/s effective) and high speed engine clocks of 1080MHz.
SAPPHIRE’s innovative Vapor-X cooling technology allows products to run not only cooler but also much quieter. A Vapor-X product means a virtually silent gaming experience and more headroom to explore performance tweaking!
Choke is an important component of the graphics card. By working with the component engineer, Sapphire’s patent pending choke is 10% cooler and offers 25% more power efficiency than a normal choke. The graphics card will be more reliable and save energy.
Improved reliability and better overclocking are possible by using only high-polymer, aluminum capacitors which posses far superior characteristics than regular aluminum capacitor for a longer product life. When operational temperatures drop by 20°C, the product life span is extended by a factor of ten, when the operational temperature increases by 20°C, the product life span only decreases by 10%.
Along the edge of the card the PCB is extended and one of the copper layers left exposed. An additional heatsink mounted directly to this copper layer allows heat absorbed into the PCB from the GPU and other components to be transferred to the heatsink and cooled by the airflow. This feature alone can reduce core temperature by 2 degree C.
Specification:-
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1030MHz >
- Memory Speed: 5300Mhz
- Warranty: 2yr
Was [£311.99] Inc. VAT
ORDER NOW
Sapphire Radeon R9 290X Vapor-X OC 8192MB GDDR5 PCI-Express Graphics Card **OcUK WorldWide Exclusive** @ £419.99 inc VAT
nonl2br
OcUK has a worldwide exclusive on the only 8GB 290X in existence, but this is not any 290X it's a highly fine tuned machine being the Vapor-X edition with near silent cooling solution. Running with a 1060MHz core clock and with memory clocked at 5600MHz makes this card absolutely perfect for a 4K setup, even more so with a pair or three of these in Crossfire. That means you could play games like Skyrim with expansion packs at 4k resolution and still not run out of VRAM.<br /><br />
Based on the award-winning Graphics Core Next (GCN) architecture from AMD with 2816 Stream Processors, the SAPPHIRE R9 290X Vapor-X is an Overclocked edition which boasts 8GB of the latest GDDR5 memory running at 1400 MHz (5.60GB/s effective) and high speed engine clocks of 1060MHz.<br /><br />
SAPPHIRE’s innovative Vapor-X cooling technology allows products to run not only cooler but also much quieter. A Vapor-X product means a virtually silent gaming experience and more headroom to explore performance tweaking!<br /><br />
Choke is an important component of the graphics card. By working with the component engineer, Sapphire’s patent pending choke is 10% cooler and offers 25% more power efficiency than a normal choke. The graphics card will be more reliable and save energy.<br /><br />
Improved reliability and better overclocking are possible by using only high-polymer, aluminum capacitors which posses far superior characteristics than regular aluminum capacitor for a longer product life. When operational temperatures drop by 20°C, the product life span is extended by a factor of ten, when the operational temperature increases by 20°C, the product life span only decreases by 10%.<br /><br />
Along the edge of the card the PCB is extended and one of the copper layers left exposed. An additional heatsink mounted directly to this copper layer allows heat absorbed into the PCB from the GPU and other components to be transferred to the heatsink and cooled by the airflow. This feature alone can reduce core temperature by 2 degree C.<br /><br />
<br /><br />
Specification:-<br />
- ROPS: 64 <br />
- Power Connectors: 2x 8-pin required <br />
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort<br />
- Warranty: 2yr<br />
Only £419.99 inc VAT.
ORDER NOW
Asus AMD Radeon R9 285 DC2 OC "Strix Edition" 2048MB GDDR5 PCI-Express Graphics Card @ £179.99 inc VAT
The new AMD R9 285 is the ultimate do it all card, great for media streaming, gaming and featuring AMD's new True HD Audio sound for exceptional sound quality and realism. This new 285 version consumes less power than R9 280 and is also quicker at the same time. As a result this is one very cool running card which also operates in near silence and will take the fight for AMD to the NVIDIA GTX 760.
Features:
- Strix Edition: Operates in silence (0dB) in light-moderate gaming (sub 65c). In higher demand games where temperature exceeds 65c fans will spin to hold temperatures down but still remain quiet.
- 954 MHz Boost clock for better performance and outstanding gaming experience.
DirectCU with 0dB fan technology lets you enjoy light games in complete silence, and hardcore gaming at 30% cooler with 3X-quieter performance!
- DIGI+ VRM with 8-phase Super Alloy Power delivers precise digital power for superior efficiency, reliability, and performance.
- GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
- GPU Tweak Streaming share on-screen action in real time – so others can watch live as games are played.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 954MHz
- Shader Architecture: GCN
- Stream Processors: 1792
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5500MHz
- Power Connectors: 2x 6-pin
- Display Outputs: 2x DVI + 1x HDMI + 1x DisplayPort
- Power: 190W TDP
- DirectX 12 Ready
- Mantle Ready
- AMD True Audio
- 3yr Warranty
Was [£189.95] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
MSI AMD Radeon R9 285 Gaming Edition 2048MB GDDR5 PCI-Express Graphics Card @ £179.99 inc VAT
A graphics card is the single most important element for more FPS. As gamers, we understand that not just any graphics card "will do". That's why we bring you the best of the best. We don't want to bug you with noise and heat, but we DO want to give you more performance. With MSI GAMING series graphics cards you get just that.
Most MSI Gaming graphics cards come pre-overclocked out of the factory. This simply means you get more performance out of your card, without spending any time on checking for maximum clocks and stability. Pre-overclocked graphics cards simply give more performance and you don't have to worry about damaging your card, it is completely covered by our warranty!
MSI's Twin Frozr has been the industry defining graphics card cooler. The first Twin Frozr kicked off the dual-fan trend and today MSI stays true to its dual-fan dual-slot design where others have to resort to less effective means.
The other part that the Twin Frozr cooler uses is a large Aluminium fin grid array that provides a huge amount of surface area for cooling. Heat from the GPU is transferred to the fin grid array by virtue of heat pipes with MSI's special SuperPipe technology. SuperPipes transfer heat twice as fast as regular heat pipes enabling an MSI GAMING graphics card to stay cooler than the competition.
Futhermore, MSI provide all new Airflow Control technology on Twin Frozr. This new thermal tech. is leading airflow to heat pipe by spcial deflector on heatsink, so it can deflect more airflow to heat pipes directly. In addtion,This exclusive heatsink design is increasing the area of heatsink so that enhancing the efficiency of dissipation much more.
Specification:-
- Core Clock Speed: 973MHz
- Power: 190W TDP
- DirectX 12 Ready
- Mantle Ready
- AMD True Audio
- 2yr Warranty
Was [£185.99] Inc. VAT
ORDER NOW
PowerColor AMD Radeon R9 285 2048MB GDDR5 PCI-Express Graphics Card @ £169.99 inc VAT
Specification:-
- Core Clock Speed: 945MHz
- Power: 190W TDP
- DirectX 12 Ready
- Mantle Ready
- AMD True Audio
- 2yr Warranty
Was [£179.99] Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
MSI Radeon R9 280 Gaming 3072MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
This MSI 280 Gaming Edition allows you to game in near silence and play the latest games such a Titanfall, Diablo 3 and many other games with ease with quality levels set to high levels. At sub £200 these are superb cards and follow on in the footsteps of the famous HD 7950 cards.
Specification:-
- Litecoin Hash Rate: 500-700
- Core Clock Speed: 933MHz
- Boost Clock Speed: 1000MHz
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5000MHz
- Display Outputs: 1x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 3yr Warranty
Was [£155.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 280 Dual-X 3072MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
With 3GB of the latest GDDR5 memory and 1792 stream processors, and support for DirectX 11.2, the architecture is built to play the very latest games with perfectly smooth action even at higher resolutions such as 2560 x 1440. In fact its Ultra HD graphics processor can feed even the latest 4K displays with the HDMI 1.4a interface. The R9 280 family represents a breakthrough in cost:performance.
Specification:-
- Core Clock Speed: 850MHz
- Boost Clock Speed: 940MHz
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 2yr Warranty
ORDER NOW
Sapphire Radeon R9 280X Vapor-X OC 3072MB GDDR5 PCI-Express Card (11221-12-20G) @ £179.99 inc VAT
High-end graphics card use more power, which means they get hotter quicker. With the innovative Vapor-X, we were the very first to apply aerospace-industry vapor chamber technology to graphics cards. It's a pioneering way to accelerate heat away from the graphics chips into the rest of the cooling system.
Sapphire Vapor-X technology is used in conjunction with a heatpipe and fan assembly. The vapor chamber accelerates the heat away from the graphics chips into the rest of the cooling system. How? Inside the vapor chamber, a liquid coolant is vaporized at the hot surface. The resulting vapor moves across the chamber where it condenses at a cooled surface. Then the liquid is returned to the hot surface to aid in superior cooling.
Features:-
- 2nd generation Vapor-X technology
- Factory overclocked
- Quiet and efficient cooling
- UEFI support
Specification:-
- Litecoin Hash Rate: 550-750
- Core Clock Speed: 950MHz
- Stream Processors: 32 CU / 2048 ALU
- Memory Width / Speed: 384 bit / 6000MHz
- Power: 250W TDP
- 2yr Warranty
Was [£199.99] Inc. VAT
ORDER NOW
MSI Radeon R9 270 Gaming Edition OC 2048MB GDDR5 PCI-Express Graphics Card @ £125.99 inc VAT
You’ve heard it before: no guts, no glory. Now you’ve got both. With the power to drive today’s hottest games — and tomorrow’s — Radeon™ R9 270 graphics keep you in the fight whatever the circumstances.
Was [£129.95] Inc. VAT
Only £125.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 270 TurboDUO 2048MB GDDR5 PCI-Express Graphics Card @ £109.99 inc VAT
The AMD Radeon R9 270 GPU continues AMD’s tradition of delivering world-class performance, features and multi-monitor support at an incredible value,” said Matt Skynner, corporate vice president and general manager, Graphics Business Unit, AMD. “With Mantle, exceptional performance and ultimate gaming experiences are synonymous with AMD Radeon R7 and R9 Series graphics cards. Once again, AMD proves that Radeon™ is gaming.”
Specification:-
- Litecoin Hash Rate: 350-500
- Core Clock Speed: 930MHz
- Core Boost Speed: 955MHz
- Stream Processors: 1280
- Memory Width / Speed: 256 bit / 5600MHz
- Power Connectors: 6-pin + 6-pin
- Power: 180W TDP
- 2yr Warranty
Was [£119.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 270 2048MB GDDR5 PCI-Express Graphics Card (11220-00-20G) @ £109.99 inc VAT
The "dual" in Dual-X refers to the two highly advanced cooling fans that are coupled with multi-heatpipe technology to cool mid-to high-end graphics cards. The fans are amazing: each blade boasts a sleek airfoil shape that increases cool air throughput so they can run slower. Even when you're pushing the processing power to the limits. Even when your're overclocking.
The quiet-running fans work with multi-heatpipes and heatsinks that take away heat from the processor to the fans. Plus, dust repelling bearings radically reduce failure caused by the build-up of dirt. In short, its a quiet, efficient way of cooling your graphics card - even when you're pushing it to the limits.
Specification:-
- Core Clock Speed: 920MHz
- Core Boost Speed: 945MHz
- Power: 180W TDP
- 2yr Warranty
ORDER NOW
Sapphire Radeon R9 270X Boost OC 2048MB GDDR5 PCI-Express Card @ £125.99 inc VAT
Specification:-
- Core Clock Speed: 1020MHz
- Core Boost Speed: 1070MHz
- Power: 180W TDP
- 2yr Warranty
ORDER NOW
Sapphire Radeon R7 260X OC 2048MB GDDR5 PCI-Express Graphics Card (11222-06-20G) @ £86.99 inc VAT
The new AMD R260X is the ultimate do it all card, great for media streaming, gaming and featuring AMD's new True HD Audio sound, which is only available on R7 260 and R9 290 models.
Specification:-
- Core Clock Speed: 1150MHz
- Stream Processors: 896
- Memory Width / Speed: 128 bit / 6600MHz
- Display Outputs: 1x DVI + 1x HDMI + 1x DisplayPort
- Power: 115W TDP
- 2yr Warranty
Was [£89.99] Inc. VAT
Only £86.99 inc VAT.
ORDER NOW
Sapphire Radeon R7 265 Dual-X 2048MB GDDR5 PCI-Express Graphics Card @ £99.95 inc VAT
The SAPPHIRE R7 265 Dual-X has 2GB of the latest DDR5 memory clocked at 1400MHz (5.6GB/s effective) and core clocks of 900MHz (925MHz with dynamic boost) to deliver new levels of performance in its price segment. Performance is optimised with the latest version of AMD’s PowerTune technology.
Specification:-
- Core Clock Speed: 900MHz (925MHz Boost)
- Stream Processors: 1024
- Power: 115W TDP
- Dimensions: 228(L)X109(W)X35(H) mm Size / 2-Slot Cooler
- 2yr Warranty
Was [£109.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Some EPIC deals from AMD here and this pretty much gives us the most competitive pricing in the UK on AMD graphics cards! :)
That 295 would be very tempting if it wasn't for 390X's just around the corner.
They are not around the corner, there will be no new product from AMD until around May-July time and then it will probably be a 380X.
It was, price error by me, if you got one we will honour it, otherwise this is the price and its a great price. :)
ACtually, I thought the price was going UP today - I mistakenly thought it was on last weeks TWO, so in fact got them for £319 at 8:59AM! :eek:
Guys in CS were nice enough to sort me to the new (£311) price though. :)
Just a pity no Beyond Earth left :(
Seeing as you've just bought three 290X 8GB cards, i can give you a Civilization Beyond Earth key. I have a spare one from my recent purchase of 2x290X MSI Lightning cards. Drop me a trust and I'll forward it to you. :)
:eek: Please be aware that you are now morally and legally responsible for my mental wellbeing should this not happen :D
Awe man, that's sweet of you.
Was going to use one and sell two, but obviously I would keep this one :)
Looking very much forward to seeing the 390X stuff. Might be the card that pulls me over to team red!
Although the price of those 290X is very tempting!
