Permabanned
- 26 Mar 2014
It's surprising the numbers of buyers rewarding Nvidia with an upgrade to a 980.
Webnote/call RMA or post in CS, they shall sort you.![]()
Yes of course.
Can one not wait for Nvidia to fix the GPU and then get the manufacturer to swap it out even if the fixed 970 cards come out in 6 or 12 months time ?
Or is it wiser just to get the refund now and be done with it?
Opportunists, seizing the opportunity for a cheap upgrade to a 980.
You would trust Nvidia that much?
They have done nothing but lie and retract statments
You only have until the end of Feb to get a return authorized.
Reading a lot of replies and research leads me to believe that it would be easier to get a refund or just stick with the card if you're running on 1080p and are able to upgrade in a year or two.
On the contrary, the 980 Reference has gone UP! I remember it being £400 before Xmas!!Cheap? how exactly.... the 970 price and the 980 price have not moved since launch.... no one is getting a "cheap" upgrade at all.
