Do you have the text file results for the scoreboard please.
You already have a better 1080p result on the board using older drivers.
Oh yeah, cheers Kaap scrap the 1080P result then. Will edit my post shortly and add the text file in.
EDIT
done.
CPU: FX-8320 @ 4.5Ghz
GPU: 1x R9 280X @ 1200/1550
Really had to push too much voltage to get it to run at that clock. I could have gone higher, but i haven't really got the balls.
1080p:
Sniper Elite 3 Benchmark Report (Mantle)
Created: 2015-01-30 at 20:21:51
Version 1.15a Build Version: 2014.12.09.001
Average FPS: 46.9
Minimum FPS: 15.6
Maximum FPS: 93.5
Number Of Frames: 3583
Average Frame: 21.317ms
Minimum Frame: 10.695ms
Maximum Frame: 63.978ms
Machine Name: BEN-PC
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 8107MB
CPU: AMD FX(tm)-8320 Eight-Core Processor
Number of Cores: 8
GPU Name: AMD Radeon R9 200 Series
Feature Level: Mantle
Dedicated VRAM: 3072MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Obscurance Fields: ON
Tessellation: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
Which drivers are you using please.![]()
. Average FPS: 105.0
Minimum FPS: 6.4
Maximum FPS: 618.0
Number Of Frames: 8019
Average Frame: 9.523ms
Minimum Frame: 1.618ms
Maximum Frame: 156.984ms
Machine Name: MALS
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 8067MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX 970
Feature Level: DX11.0
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: OFF
Vertical Sync: OFF
Stereo 3D: OFF
i wonder how the rig would perform if i upped the OC to 5.1
Average FPS: 103.8
Minimum FPS: 17.6
Maximum FPS: 770.3
Number Of Frames: 7886
Average Frame: 9.635ms
Minimum Frame: 1.298ms
Maximum Frame: 56.746ms
Machine Name: MALS
Monitors: 1
System RAM: 8067MB
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
it's faster with motion blur on ............... latest GPU drivers ( no choice)
MSI Afterburner from top down = no volts then + 100......+ 69...........so the cards are on about 30% overclock, down from 60% for about the last month
cpu is down from 5.2.........to 4.8........to 4.6 right now
Sniper Elite 3 Benchmark Report (DirectX)
Created: 2015-02-01 at 00:05:55
Average FPS: 66.1
Minimum FPS: 6.6
Maximum FPS: 928.9
Number Of Frames: 5034
Average Frame: 15.130ms
Minimum Frame: 1.077ms
Maximum Frame: 150.715ms
Machine Name: HAL
Monitors: 1
System RAM: 16265MB
CPU: Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz
Number of Cores: 16
GPU Name: NVIDIA GeForce GTX 980
Resolution Width: 3840
Resolution Height: 2160
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Scoreboard updated.![]()
Thanks Kaaps. I'll be back soon to beat your 4K quad score.![]()
