- 27 Mar 2014
- Newcastle Upon Tyne
Hi guys,
I've been doing some general upgrades to my friends. PC and one of them was replacing the stock AMD cooler which is running funny and generally just needs replaced. However today when I took out the mobo and un clipped the heat sink. It was really stiff and tight, after a little wiggle it popped out. Only with the CPU still attached to it!! I've heard of this before but never experienced it myself so I was kind of shocked.
I'm worried about damage to the CPU as it was still locked in. Pins all seem fine...lucky
I've tried removing the excess thermal paste from around the heat stink but it's still jammed down tight.
I've tried using dental floss to try chip away at the paste but it looks like there's not even enough to do that.
I'm worried it's just actually fused together over the years of use and I can't get it off and I can't get it back into the slot because it won't lock in with the fan in the way.
He's currently using a ASUS Crosshair IV formula but I can't seems to find any plan AM3 socket CPUs they are all AM3+. Would one of those fit in this mobo? I don't think it will, but read online some mobo's can handle them.
My last option I can think of is using my heat gun to try loosen the paste but I'm worried about damage to the CPU?
If not looks like its a new mobo and CPU?
Any thoughts/help would be greatly appreciated.
