- 6 Jan 2013
- Rollergirl
Before I pull the trigger, is the ROG Swift the only worthwhile choice?
If your gpu cant do 4k then it cant do 120fps at 1440p
My GPU will be a GTX980. Are you saying that can't handle 1440p @ 120fps?
G-Sync could be overlooked, but it needs to be at least 120hz and 1440p. There's no point in 4k as I won't have the GPU power to drive it, plus I want 120hz smoothness.
I'm saying that to get 120fps at 1440p is as demanding as getting 60fps at 4k.
OK. I know I'm not going to get 120fps in AAA titles with everything maxed out, but I want the option of 120hz or anything from 60hz - 120hz in those games that will allow it.
As long as I'm getting 60hz minimum in most games, and the option to go higher. That's why I'd want G-Sync too... for situations when refresh is set at 120hz and the GPU can only drive 80 etc.
Fair enough, from my experience when running a 120hz monitor i dont notice frame tearing when running under or over 120fps. However on a 60hz monitor i notice it quite badly.
I'm waiting on the Acer Predator XB270HU coming at the end of March (though I anticipate possible delays). 1440p, 144Hz, G-sync IPS panel, but if your anal about response times the Swift is probably the best choice. If what spoffle says is a good estimate of 4K performance then I hear good things about the Acer Predator 4K2K XB280HK which is available now.
roll on April!
