Oh man i just discovered that random vampire attacks kill actual quest NPCs. The Completionist in me is about to lose my mind.
These 2 look pretty dead man.. are you sure?
Yep did all the latest tips and tricks at the time including LOOT etc. Like I say none of the mods were scripted anyway and also why 80 to 90 hours before issues arose... strange but it was a deal breaker for me at the time.
I had an issue when I last heavily played Skyrim last year, I would be grateful for feedback on.
Every time I played Skyrim, starting a fresh with a new character, I found it would be 100% stable until about 80 to 90 hours in, where by it would start crashing every hour or two. The crashes could be anywhere outside, just wondering around Skyrim. I re-rolled 3 times and each time I'd get 80 to 90 hours in and stability would suddenly become an issue.
Yes my skyrim was graphically modded but done correctly with sorted load orders etc and none of them were scripted. I also played with the unofficial patches, official patches and all dlc.
I'd like to return to Skyrim but not if its going to always become unstable, just when my toon just starts to get into the higher levels. .
Well you're just going to have to try and track it down aren't you, theres no simple magic wand you can wave here to try and make it better. Most of us have had these problems at some point or other and have to turn detective to try and track it down, remove one mod at a time, check it, does it crash? No? Try another, etc, etc. Its a pain but once you get it sorted leave it alone and you should enjoy many trouble free hours.
The bottom line is, if you have No Mods At All, completely vanilla game clean install, deleted absolutely everything from Steam and both it's .ini files, redownload again started a Brand New Game from scratch does it still crash then? Because if not your problem is somewhere in either
a) the mods you've installed
b) the graphical enhancements (ENB's, if present)
c) the savegame has a problem, unattached instances, orphaned scripts, in which case you'll have to try a savegame script cleaner.
If its STILL crashing when EVERYTHING is vanilla you have problem with your computer, checked all the drivers? Hardware? Done a stress test on the graphics card? Memory?
Like I say there no magic wand to wave here just some good old fashioned detective work.![]()
I'm trying this today/ right now! Have to say, it's really nice.
I had to run 'Ordenador texture optimiser' though as my 780Ti's were being pushed to their 3GB memory limit with this. Since running that and a few other tweaks I seem to have as good if not better performance than what I was using before.
I sooo. thought it was the SKSE memory fix.
Its either a hardware (mem lack of) issue or a very specific mod we are not using.
But I cant think of mods which would cause problems afters 80 hours?
Its not hardware, 16GB RAM, GTX780 back then and now SLI 980's. Besides it would have shown issue far earlier on.
I believe its something to do with the save file and/or connected with late game progression when many more cells are populated and in need of cleaning. Possibly of course
There are some who believe that when you get further on and the save file goes beyond a certain size (not talking about extreme bloat here) that the game can be more prone to falling over.
I'll see how I get on, but if it happens again this time I know its just the game and some combination of how I've been playing it. If not then it was mod related.
I've got some tricks up my sleeve either way this time if it happens that I will be trying, involving cell cleaning/resetting, possessive corpses and possibly even save cleaning as a very last resort. However I'm hopeful that it was simply mod related and the fact I'm not using any now will be the fix itself.
I'll update in a few weeks time when I get that far.![]()
I went through all that save cleaning malarkey when I was about 100 hours in and it didn't work as my saves wern't really the problem (not bloated). I had given up on the game just as the skse memory patch was released. I'm now carried on approaching the 250 hour mark with no crash to desktop or corrupted saves.
Can you recheck that skse + the memory patch is installed correctly? Others have stated that additional fixes like the double cursor fix have interfered with skse working correctly.
http://www.nexusmods.com/skyrim/mods/61995/
Massive graphics overhaul of almost every area in Skyrim. Be warned, files are large especially if you want the one with some 4k textures in. Parallax effect patch as well.
Try running the 4k textures, JK's town expansions and an enb - made my PC cry![]()
