** A NEW BEST SUB £300 CARD? AMD 290X 8GB!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We have potentially a truly future proof 1440P & 2160P card when your running them in at least crossfire, 3-way recommended for 2160P. If your gaming at 1080P then a single card should be more than future proof for years to come even on the poorest console ports which could be using around 6GB of memory:
MSI Radeon R9 290X Gaming Edition 8192MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 8GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290X
- Backplate included: Yes
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1040MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 8192MB GDDR5
- Cooling: MSI Twin FrozR Gaming Cooling
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Was [£329.99] Inc. VAT
Only £299.99 inc VAT - Stock due end of this week!
ORDER NOW
With an 8GB card you have no worries of running out of memory for a long time for sure, for 1080P one of these should be more than enough, a pair should be no issue at 1440P and OK for 2160P and three would be great for 4k gaming.
Also some other industry leading deals we have are:
MSI Radeon R9 290X LE Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £249.95 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1020MHz
- Memory capacity: 4096MB GDDR5
- Warranty: 3yy
Was [£269.99] Inc. VAT
Only £249.95 inc VAT.
ORDER NOW
Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1040MHz core and 5400MHz memory.
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290
- Coil Whine Reduction Technology (Exclusive to Powercolor)
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Memory Speed: 5400Mhz
- Cooling: 2-Slot Blower Fan
- 750W or greater PSU required
- Warranty: 2yr
Was [£227.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
For the performance the 290 range offers these are pretty amazing deals!!! :)
Yeah nows the tough part the 290x 8gb or powercolour. Anymore bargain 290/X's coming up?
What are the 290x 8gb gaming like for temperatures? Also how long are these prices valid for?
One card 65-75c under load, two cards upto 85c underload. 3/4 cards will need fans at 100% and good ventilation to stay sub 90c ideally.
On this design, three cards is the maximum we recommend and the cards should have spacing between them.
Will an 850W EVGA G2 PSU with a OC'd 5820k @4.4, 16GB RAM, x2 SSD's, x1 HD, Nepton 240M AIO, and x4 additional fans run x2 of these cards in Crossfire without getting upset?
I can understand the appeal of the 970/980 for power consumption and temps but if I had a 970 and was planning to rma it due to the VRAM issue that £299 8gb 290x would be a lot more tempting than a £399+ 980.
