- 24 Sep 2013
- Exmouth, Devon
RE: OP..................................No!
It's ** Been removed as a competitor **
I'd also like to throw the Samsung 32" 1440p in for your consideration. I own one myself and it's lovely.
http://www.overclockers.co.uk/showproduct.php?prodid=MO-205-SA&groupid=17&catid=2898
Will never understand ALX.
Makes thread about 4k, doesn't want 4k. Gets 1600p, moans that we're making him feel upset because he made a terrible decision with his purchase. Claims 4k in pointless as it means playing at 30-40fps, and there's nothing about in his budget range - despite people showing him otherwise....he then, goes and gets a 4k monitor above his original budget...?
Not that i care, buy what you want. As for X99, what did you say? I honestly cannot remember.Ego much.
Shankly thinks i follow him around, humbug thinks i follow him around. Admittedly, it's only be you three to come to that conclusion, most other people understand i'm always on these forums so just post.
Not a clue why you quoted your card prices, lol. The fact you've mentioned them probably means you thought about the budget a bitNot that i care, buy what you want. As for X99, what did you say? I honestly cannot remember.
What do you have against display port?
Also, do you realise the monitor you ordered ONLY has display port?
Personally, I'd never buy a B-grade monitor, as could have backlight bleed, bad IPS glow, or be cosmetically damaged in some way. Or it could be perfect with simply a bit of minor box damage. You just never know, and it'll cost you to return if it's something minor like that.
Gsync doesn't magically make 30-40fps super playable or fun (my opinion) it still feels sluggish.
i'm only holding off , waiting for the refresh of gpu's then i'm going to be going through the same pain, and I can sympathise. i'm not looking forward to making that decision.
I can't make my mind up on viewing ratio, ips over response, resolution 1440 or 4k.
It's an absolute minefield, then the comments like your lucky to get a perfect one .
its a complete lottery.
