Ooh. Balancing seeking luxuries...no more millions to be made then.
Balancing Python...it's been a long time coming apparently (I've never owned one)
1000ly route planner..yay
Could definitely do with some help, not even played the game yet, still in tutorials, getting my butt kicked on wave 4 or 5. Can't seem to get the hang of turning in a dogfight, any hints?
Edit - Forget about the controls, did some more playing around, just help me make those turns!
I tried FaceTrackNoIR with my Xbox 360 webcam, and it worked reasonably well..
I tried FaceTrackNoIR with my Xbox 360 webcam, and it worked reasonably well. I think with a bit of tweaking to the various curves and settings it would be nice cheap solution to head tracking.
However... I found I got neck and shoulder ache from sitting relatively still in front of my PC. I think what I've found out is that I like to jiggle about in my seat as I play, which I can't really do when using the webcam as it causes the view to go into a spasm!
The button on my HOTAS that I used to switch headlook on and off before using the webcam stopped working whilst FaceTrack was running, so I couldn't even disable headtracking during general flight and just enable it when I wanted it.
So I've uninstalled it all and will live without it. Shame, as it could have enhanced the game loads. It also makes me a little nervous on spending cash on a solution, as I don't want to end up with neck and shoulder pain after trying to sit still during a gaming session.
I'm in Tenche at Blaauw Hub, making 659k every 4mins in my Type9. There is a S.L. 7.22Mm from the port, so you can just stay full throttle and it takes about 8 seconds in sc.
I look back at how hard I worked to get the Cobra and I am earning a cobra and 2 vipers every 4 minutes - madness.
But when you consider that a fully tricked out an A grade Anaconda can cost 640million that is about 60 hours constant trading, getting on for 2 working weeks.
It would be lovely if there was an alternative to trading as a money making method.
I've just crossed 100million current assets so still so far to go - I really want a heavy fighter in the game, kind of like a fighter version of the Asp.
Shields are expensive on the conda, as is the thrusters, as is the reactor![]()
I guess you've not seen uprated bulkheads........ ?
I think mirrored surface composite was 346Mcr for the Anaconda last time I looked.....![]()
Whats the deal with NPC pirates? do they just kill you or can you drop cargo and they let you live?
