Pyr0m@nI@]{;27578782 said:same bios and fan speed here too
For those that may still be undecided, here's some benchmarks for comparison :
Firestrike Extreme, stock settings :
Firestrike Extreme, +150 core +250 mem :
Heaven 4.0, stock settings :
Heaven 4.0, +150 core +250 mem :
Personally, I'm happy with the switch.
hopefully ill have an update 2mo regarding the bios information
Our first impression was that the fans were running too quick, and Galax appears to agree - a BIOS update was made available this week that reduces idle fan speed from 50 per cent to 30 per cent. All three fans could, we feel, be turned off when idle with no detrimental effect, but we're told that a completely passive mode won't feature on this particular card.
I don't think it is that high, not in every day game usage etc. 15-20% is the figure I have seen many times, and that's probably more accurate. A benchmark isn't necessarily reflective of what you'll get in games, which will vary significantly.I didn't realise the difference between the 970 and 980 was ~25%. Quite surprised by that. I suppose that is a worthwhile upgrade.
String what do you get on the standard firestrike tests at stock with your CPU at stock as well? I'm just shy of 11k with everything at stock spec in sig.
