The problem is, that it's not actually possible to test the hardware without the software...and while I agree that the standard safety testing stuff, EM/RFI compliance will have been done to death, any modem testing in the UK was clearly inadequate.
I posted a link earlier that shows the modem hardware has been fully tested.
http://www.prnewswire.co.uk/news-re...trac-broadband-test-laboratory-231716931.html
THis testing is basically the same any device goes through including BTs. (which isnt even BTs but another manufacturer in a BT branded case)
If the the whole ASUS modem router platform was compliance tested in the UK, there is clearly a problem with the compliance test.
No it would have met ITU requirements, whether it was tested here or elsewhere. http://www.itu.int/en/about/Pages/overview.aspx makes no difference. You can not find a problem in hardware testing if there is no problem.
The stability of the modem on release was diabolical and although it has got better, the connection speed issues are still a problem.
Its got better because it is SOFWARE RELATED not hardware. If it were hardware which was the issue it would had not improved.
I would hope that if BT did the testing
BT do not do testing they have a SIN sheet for recommendations to other providers (ISPs) and what their gear should support for the wholesale network. Nothing more.
then it would reflect the real world conditions or the worst case conditions for a UK phone line....but this doesn't seem to be the case
Again BT dont test they just have a SIN sheet, no routers are tested by BT, the openreach modems just went through the same tests as ASUS gear nothing more. The Huawei vesion of the Openreach modem you can buy worldwide, you dont think BT tested a Huawei device for the worldwide market do you? The only different with the full on Huawei branded version is the case, the circuit board and the firmware it can take is EXACTLY the same. AND I MEAN EXACTLY NO IFS OR BUTS.
Still, nobody except ASUS and Mediatek actually know if the problem is software or hardware.
If its hardware what do you actually think the issue is? Its software its obvious its software related the reliability alters depending on software version the hardware dont change.
You may make an educated guess that it is software,
There is nothing to guess.
but you cannot know. The reason I've taken issue with you stating that it is definitely software is simply that if it is the case, then it can be fixed. While we equally cannot know if this is a hardware issue, we have to entertain the notion that ASUS may not ever be able to provide a fix.
Its software and until they find the issues in the software then no it wont work to its full potential its that simple, i have no idea why you keep thinking its hardware when this device along with every other EU device meets the same ITU specs. Has undergone the same testing and so much more. Its Asus at fault with the software, its nothing to do with the hardware inside.
What they should have done is issue a UK only firmware version and work from that point forward with settings applicable to the UK only. Things like USPBO, Bitswap etc should not be configurable when they are a requirement.
Then they can start adding the extras as and when the UK VDSL spec changes such as G.INP and Vectoring with a good base firmware to work from.
Whilst mine is now stable, having to kill processes to maintain a steady connection makes Asus look unprofessional, lethargic at responding and somewhat carefree.
Exactly this would be the ideal solution, however for whatever reason they have not taken it. Personally i think a lot of the software needs a full rewrite or extrenulous bits of it (like the spectrum page) just removed entirely. Its certainly not hardware, even more so when the bulk of the complaints are from UK VDSL users. The fact yours also suddenly becomes stable just by stopping a bit of the software running also shows its software issues, i have no idea why he thinks its hardware or where or why he thinks BT should be testing it. Its patently obvious the software is at fault especially when ASUS have had issues with ADSL and VDSL side of things in prior devices, so unless all those were dodgy hardware, its again obviously its Asus and their software.
