Just come back from the Doctors, he said I might have Glandular fever
no biking for me still then![]()
Arrrr man!! Gutted for you dude!
WAs doing a session on Trainer Road tonight and about 30 minutes in I got the most horrific cramp in *both* calves
Anything I can do to avoid this in future other than making sure I'm really hydrated? Should probably get a bike fit at some point too...
Hydration will help - and not just water if you're sweating a lot. You'll want some delicious salty goodness in there too (hydration tabs).
A bike fit is the best thing since sliced bread so you'll do well to get one too, yeah...However, cramp isn't that common a symptom of a bad fit (I think - someone else may be able to better comment).
Really need to get my bike fit sorted, inner knee pain when I push hard which I can't seem to get rid of by tweaking my saddle/cleats![]()
Ever happened before??
Interestingly it happened towards the end of a 12 minute section where TR wanted me to use a cadence about 10 below my usual one and at 90% of my FTP. I've had it once before on an outside ride when I pushed pretty hard.
I haven't drank much water today but have drank lots of diet coke which will not have helped.
Gonna do the workout again tomorrow and make sure I'm well hydrated.
What frame did you go for?
Nothing to it. I usually just bash the cups in with a hammer and a block of wood. With a press, it'll be a doddle.The main bit worrying me is fitting the headset, but I've got a press so it should be ok.
If you know what height you need (from taking measurements off your other bikes) then cut it to that height. Otherwise, leave it full length and run it with a stack of spacers above+below the stem for a week or so and cut it when you've worked out what height suits you.That and sawing the fork, but that looks doable.
I think if you follow the training plans on Trainer Road you'll get the most cycling improvement for your time buck. This will leave you with more time to enjoy the fruits of your labour - at least when you're not recovering from the horribly painful sessions at least![]()
), not had time for a proper troubleshoot yet...Really need to get my bike fit sorted, inner knee pain when I push hard which I can't seem to get rid of by tweaking my saddle/cleats![]()
Where are you based? If anywhere near Manchester/Stockport then Freeride Cycles in Disley will sort you out with a really basic bike fit for ~£35. It's not quite as good as a proper fit but on a scale of no fit to proper fit it's well over the half way point.
Now *that* sounds like it's very much down to fit. Lower cadence generally speaking = more pressure being put on your joints when you cycle so it's often likely to make issues with your set up worse.
Tried reducing tension on cleats for more float?
I'll be picking up the on one pompino for £200. It's low end steel, with a steel fork, but it's cheap and it's got proper track ends, so it'll do the job. It's also got mudguard mounts, which I want. It's got canti mounts, so I'm fitting mini vs, which will be a bit weird. I'll let you know how it turns out next month...
It'll be the first bike I've built from scratch. The main bit worrying me is fitting the headset, but I've got a press so it should be ok. That and sawing the fork, but that looks doable.
