Meant behind the cards in front of the hdd cages, though tbh mate i have tried the method you describe too.I'm thinking he means behind them outside the case not In front of them , I could be wrong though![]()
Just remember you still need to use the two blower fans from your Titans with the HG10. Although hopefully this time you wont need to run them at 100%.![]()
Thats handy, im toying with the idea of getting a sheet of acrylic and just making a temporary side panel with a fan cut out. Wont need a peice to cover the whole area of the side panel. The 5.25 bays and hdd bays on the primo are all sheeted off. So ill just butt it up against that part. Would save the bother of cutting the stock panel.The case side has two 120mm mounts right over the GPUs. Thing is that whilst they will feed cold air to the blowers they won't stop the blowers spinning up.
It's actually looking like Corsair will be shipping out the N780 soon so will deffo hold out for that![]()
Won't the bottom aio huff n puff n gurgle fitted in that orientation andy, aren't the pipes meant to be flow properly when at the bottom?
Andy wish id seen this earlier have loads of left over watercooling gear in the loft that you could use for some ghetto modding PM me up and i will have a dig about.
Will do mate, and thanks I appreciate that !
Just a quick update. OCUK (DAMN YOU !!) had the Kraken G10 for a mouth watering £19.99. That coupled with free shipping and my eternal impatience has netted me two and they should be here soon.
Currently selling off some old PC gear, so basically will have the funds spare to buy about 40 little heatsinks lol. I counted earlier, TB has 12 memory modules and I would need another 8 for the fets. So I will be sorting something out on that front.
Damn you Andy!! Just ordered one myself as I bought the heatsinks for it ages ago on the MM. Have been waiting for a price drop, now I just need an AIO cooler to put in it...
surely due to fan design the corsair one would be the worst choice
ahh well nvm I see you went kraken.
