- 18 May 2010
Ok thanks, how long do you run realbench for?
or go bananas on benches hehe. You could try nudging the fsb a bit to eek a few more mhz out, but watch out for your other linked speeds like ram, nb and HT, you may need to adjust the ratios to keep in spec or keep desired speeds.
Core performance boost - disabled (I read this is best disabled)
Leave as disabled
CPU Unlock - disabled (Was already disabled)
This is to unlock x3 to 4x cpus etc. Leave as default.
Cool & Quiet - Enabled (Enabled after successful stress testing, is that the norm?)
Conflicting info on this. I normally disable.
Best to leave it on it gives you good idle clocks and if you master offset voltage, then you'll benefit from low v-core when idling. Very common that people believe this is a cause of throttling or withholding performance which both are incorrect.
C1E Support - Enabled (I read this best enabled)
this is low power state at idle/low use. Probably best disabled for best performace.
Leave on no issues with holding back performance.
SVM - Enabled (No idea what this is)
Probably the virtual stuff, leave disabled unless you will use it.
CPU Core Control - Auto (I read this is best enabled)
Auto should be fine or you can enable and make sure all cores are available, but it shouldnt make a diff.
Core C6 State - Enabled (Recently read its best disabled?)
Another low power state setting. Again, I normally disable. Once you have got everything configured for performance, you can try re-enabling these sort of setting to see if it causes issues and reduce idle power. For now set to disabled.
HPC Mode - Disabled (No idea its on default)
Stops low power states and some other things. Potentially its faster but at the cost of heat apparently. I disable this and have seen no diff with it enabled.
Can either be left on or off.
APM - Enabled (No idea its on default)
I believe this to be thermal control (72C limit I mentioned) Leave enabled IMO.
This is the main reason for throttling on Gigabytes sometimes, make sure it's disabled.
I cant post images yet I dont think but my scores are this (Remember I have 280X xfire)
Image Editing 8008 - 107.239
Encoding 93521 - 128.185
OpenCL 100032 - 2606
Heavy Multi 88424 = 110.603
System 70489
If start the bench then cancel out straight away, then run again, the image score will increase.
Since you seem to have your core clocked to a reasonable lvl, you can start looking at OC the NB and HT. I run my NB in the 2600 and HT the same as its supposed to give best performance. NB and HT at anything 2500+ should be fine. NB will probably have the most impact on performance but not by a lot. Mine NB doesn't like anything over 2700. You may need to adjust the volts for these up to achieve although, again, this can be different for each MB.
Also I'm not sure it will make a diff, but change the GPU settings to performance.
Looking at your results, you dont seem to be that far behind. You could also try setting the LLC up a lvl to see if extra power is needed.
If your cooler is not up to it, run it between 4 and 4.5Ghz for now and look into what cooling you can get for your case.
I just set all the power saving features to off.
"Do you mean uber mode on the gpu? If so its already on."
It should be in CCC under 3d app settings - Texture Filter Quality - set to performance (You may want to set it back to standard or high q later though)
I think if you have set something to "Uber" (Means super?) its probably the Anti-Aliasing Method you have set to super/uber sampling. If this is the case, that is the slowest but best quality setting, so it a massive hit on performance. Set to Multisampling for better performance (at a slight cost of IQ)
I wish I could help further with your cooling prob, but I have no idea how anything can be hitting 90c without crashing the system. Maybe put a small fan aiming at VRM and base of the cooler?
Which cooler is it you are using?
Anyway just want to make clear, I'm no expert at any of this but if I have given any false info. Please do let me know. GL
/\ great advice from Scurburg, with my opinions and views in orange.
I would try occt as this program will show logs as to whether your cpu is throttling behind the scenes. an example is here http://forums.overclockers.co.uk/showthread.php?t=18639472
This cant be right, surely the chip would brick itself if it was!
its just to hot with any higher settings I need a better coolerThanks Th0nt, I'm down to 4.4 with 1.344V nowits just to hot with any higher settings I need a better cooler
bennyboy that was similar to my settings and it was stable when stressing but what heat is it putting out as i noticed in some of your previous posts it was a bit hotter than mine and anything over 60C on these for extended periods isnt good from what I've read, what cooler do you have?
I think mine is staying at 4.4 until I get a new cooler as with all the help I've had and all the different clocks and volts I've tried I really am starting to think that everything points toward my CPU cooler, what do people recommend? Most with my case seem to go for a H100i
