Man of Honour
- 16 May 2005
- Manchester
Weird that. I've had my current chain on for 18 months during which time it has done nearly 6000 km in all kinds of weather and I've never had rust on my chain. Maybe its the lubricant that you use? I use Finish Line Green for the winter and Finish Line Red for the summer.
You generally don't cycle in bad weather though right?
I don't tend to get rust on my chain but I'm normally quite good about cleaning it and re-lubing it.
@Roady. You only need to apply lube to the links. Use a cloth to wipe of all the excess lube. Like, every single bit you can get off. Also give the jockey wheels a wipe too.
