Cheers ladsNew cards from AMD are just around the corner so i'm at that suicide run stage, we all have to go sometime even gpus
.That needed about 4.4v
something not right with that, you are WAY under where you should be.
Updated.![]()
Oh really?
Where should I be bug?![]()
Should be around 10 FPS higher
Somehow when I run Thief benchmark with Mantle Crossfire, the game freezes and the driver crashed with the 'the display driver has stopped responding' error.
Any ideas?
When you start it click on Options use these settings.
OK I went back to basics and noticed my RAM speed was pretty low so I forced the setting in the BIOS to be nearer its rated speed:
I think you were spot on almost a 10fps increase.
Quick run!
i7 3930k @ 5.1Ghz
290X @ 1300/1625
Mantle
Fish Oil
1080p
No idea why the scores low for the clocks used.
Hmm! well that eliminates you running a more efficient Cpu being the problem.
Turn off HT and you get a little extra boost.
I found my reference card was so much faster in this. Wonder if it's a Hynix thing, can't see what else it could be.
Shouldn't be ram difference because it doesn't effect 3dmark.
