- 21 Jul 2005
- Officially least sunny location -Ronskistats
I have a refurbished H100 (not i) and it keeps the temps in line pretty well.
I've finally kept it below 60, I know what you're saying about it being OK to go over but I feel more comfortable with it staying under
The below is at 4.5 and that's where its staying for now, appreciate its only 30 mins but on previous tests and bench's it would have hit 64 in that time
Edit - just realised HWMONITOR isnt showing the CPU temps in the pic, it was 56C max
With the comments on here talking about low volts with E processors, this is the last peice of my build puzzle. Am I better to go with an earlier suggested 8320e or do I get the 8350 - confused!
The 8320E will probably be the better overclocker, so i'd go with that.
What are your package temps? and I take it you are manually selecting your core voltage for the moment.
(sorry couldn't resist)
will end up replacing my air cooler with most likely a 80i or 100i.....Hey Dave; Thont; Matt......quick question as I'm going to be spending my tax return soon......I know Asus Crosshair is a beast of a board but I've been hearing that the sound chip tends to fail on them....my only consider on that board;
its either that or sabertooth; both have 8+2 phase; only board that I know of that has more is Asrock Extreme 9 with 12+2 phase lol....
I'll be snagging a 8320E for under a 100 quid soonwill end up replacing my air cooler with most likely a 80i or 100i.....
I really wouldn't recommend buying a new AMD motherboard and CPU to go with it at this point.
It's 2015 and these AMD components have been out for 2-3 years.... The motherboard feature set is very dated, modern platforms on Intel (z97,x99) are way more up to date and will last you much longer.
I'd recommend a cheap Z97 board and a I5 4690k/i7 4790k, if you want your new build to last you a few years. Z97 has an upgrade path coming soon (Broadwell) and it supports all the latest technologies on the motherboard.
I know I'll get negative responses as this is an AMD thread - I really wish AMD had something new out, if it was competitive with Intel I'd be on that setup right now. We just have to wait for Zen, in 2016/2017, for anything new from AMD![]()
I had a 6950 reference card that hit around 90-95 it's perfectly normal temps for a amd reference card..I still think you have head room left. You need to be a bit more relentless IMO(sorry couldn't resist)
Highest I see is 62 so looks good to me. Your GPU is getting a bit toast at 94 though in the second shot.
AMD matt when we going to see new chip sets and mobos from amd been way to long.
