OcUK Staff
- 26 Nov 2014
- Stoke
Since time began, many have asked for a HAF X in Blue, and now thanks to OCUK and Cooler Master it can be so. For a limited time only, the Cooler Master HAF X now comes with 3 FREE Mega Flow 200m Blue LED Fans, exclusively from OCUK.
Plus you get a 230mm Red LED Fan and a 200mm Black Fan that's already pre installed to chuck into another build or sell on to make the deal even better
Cooler Master HAF X Gaming Tower Case - Black (RC-942) @ £129.95 inc VAT
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, GFX cards and is even USB3.0 compatible. With specialised support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this is as close as it gets to a system builder's 'dream case'.
- Dimensions: 230 x 550 x 590mm ( W x H x D)
- Motherboard Compability: Micro- ATX, ATX and E-ATX
- 6 x 5.25" Drive Bays
- 5 x 3.5" Drive Bays
- I/O Panel: USB3.0 x 2, USB2.0, Audio x 2, e-SATA x 1, FireWire x1
- Cooling (Front): 230 x 30 mm red LED fan x1
- Cooling (Top): 200 x 30mm fans x 2 (1 included)
- Cooling (Side): 200 x 30mm fan x 1
- Cooling (Rear): 140 x 25mm fan x 1
- VGA Fan Duct: 120 x 25mm fan x 1 (not included)
- VGA Holder: 80 x 15mm fan x 1 (not included)
- PCI Slots: 9
- Base Mounted PSU Bracket
Only £129.95 inc VAT.
ORDER NOW
- PCI Slots: 9
ORDER NOW
