Speakers and headphones simultaneously
9 Jan 2011
I've just fitted a Sound Blaster Z series card with mic, headphone and surround sound speaker outputs.
I would like to have the option of either using the phones, or the speakers, or even both together but can only get sound through either at any one time.
I've tried right clicking Stereo Mix > Properties > Listen > Playback through this Device, and selecting all the options one by one, but can only get sound through the headphones. The only way I can get sound through the speakers is to physicaly remove the headphone jack.
Is there a way of getting sound through both ?
Thanks
Ron
18 Oct 2009
You can't use both simultaneously (never understood why some people want to do this), but you should be able to switch between speakers or headphone without having to physically remove one or the other.
Creative did this with the X-Fi Titanium HD. You had to remove speaker or headphones, depending on which you wanted to use. Stupid design, and something I thought was remedied with the Z series of cards.
I've not see anyone else mention they need to remove speakers in order to use headphones, so either you're not doing something right, or something is wrong somewhere.
Surely Creative would not be so dumb to make the same mistake twice? ;)
3 Sep 2012
P town
It's simple some people prefer to use speakers but when gaming they might need to use a headset so it can be easy if both are enabled simultaneously rather than having to switch between the two.
But yeah OP shouldn't have to physically remove a device, have you had a look in the windows mixer under playback devices?
25 Jul 2012
Ankh Morpork
I always had my headphones and speakers plugged in at the same time when I used my SBZ and just used the software switch in the control panel to switch between them.
As for hearing both together - no idea.
18 Oct 2009
So switching between the two is too much effort?
It's really quite amazing how someone can move a mouse around and press some keys on a keyboard whilst playing a game, but going to their sound card options and switching between speakers and headphones is too much effort. :/
I really should have guessed it would be that. I was thinking people were trying to listen to both at the same time!
25 Jul 2012
Ankh Morpork
I used the headphone socket on the card by the way, I never use front panel sockets for anything except USB as they pick up too much noise.
It may be that the front panel socket is forcing the removal of the headphones, the socket on the card doesn't have this problem.
OP
9 Jan 2011
Guys,
Thanks for all your info.
The reason I might want to have both working together is that at times there will be more people than myself in the room, and due to my partial deafness I much prefer to use headphoness rather than having speakers too loud for others to listen comfortably. It's not because I can't be bothered to switch betwen the two as has been suggested.
Please excuse my ignorance, but can someone explain how to switch from one to the other ? As you can guess I don't have a great deal of experience in this.
Thanks
Ron
6 Feb 2010
Guys,
The reason I might want to have both working together is that at times there will be more people than myself in the room, and due to my partial deafness I much prefer yo use headphoness rather than having speakers too loud for others to listen comfortably. It's not because I can't be bothered to switch betwen the two as has been suggested.
Thanks
Ron
The Soundblaster Z soundcard actually has the headphone jack and Front audio jack as two seperate port, so you should be able to switch between the two back and forth using the Creative's bundle software/control application.
Though it still wouldn't allow to you have both the headphone and speakers playing at the same time.
18 Mar 2011
Lancashire
I personally have always just used 3.5mm splitters with whatever headphone/speakers/soundcard i have had. Currently the same with some Logitech 5.1 speakers (which to be honest i don't use that much these days). A pair of Kingston Hyper-X Clouds plugged in to my Xonar D2. Yes the D2 may not have a Amp but it certainly drives the Clouds enough i would say.
So why can't you have headphones plugged into the heaphone Amp output and speakers from their intended sockets? I can't remember the exact configuration of the "Z" series of cards as i only had one for a day before i took it back...
22 Oct 2018
Any "effort" that is redundant, unnecessary or illogical should be done away with ideally, no matter how miniscule the amount of effort is. So this is not a good argument.
More importantly, the actual case that involves significant "effort" is thus: I'm playing a video game e.g. Skyrim with headphones on, my ears are getting very tired and uncomfortable, and it's very easy to just take off my headphones and turn on my speakers. Or I started with speakers because I was feeling casual but now I want better positioning so switch to headphones. Why should I need to alt-tab, launch a new program, change some setting in it, and go back to the game? Some games even respond poorly or have a chance of crashing when you alt-tab.
P.S: Here is another use case. I am watching a movie with headphones and want to get up to get some water, but I want the sound to be completely seamless WHILE i'm getting the water, and never lose the immersion. So I turn on my speakers first, then take off my headphones so there's no break in audio. I get my water, come back, put on my headphones and turn off my speakers.
By the way, it is much easier to unplug my headphones (from the front module) than to alt-tab, launch a new program, click into another tab and click a switch. So I find it sad and hilarious that they advertise "Never unplug your headphones again!" Because what they're really advertising is "We removed the ability to switch to speakers by the simple mechanical act of plugging/unplugging and now you have to go through a longer process to switch between them"
6 Jun 2008
Finland
You sure digged up long time dead thread.
But it would be equally redundant to always need to plug/unplug headphones for switching between them and speakers.
Besides causing wear of connectors.
And you can't just use same signal for headphones and speakers, because of drastically different way how ear receives sound from them. (or possible different number of channels)
Listening speaker mix with headphones sucks, because of lack of anykind interaural cues. (listening just front channels of 5.1 would suck even more)
Again binaural sound just wouldn't be natural from speakers, with "double crossfeed" for start.
Anyway for SB Z-serie SBZ Switcher automates switching between headphones and speakers and wanted settings behind hotkey.
