- 4 Feb 2011
- Halifax
Why don't people just use Yatze? Works flawlessly for me.
+1 for Yatze.
Giving the Raspberry Pi 2 a serious look atm.............
One of my work mates keeps wispering do it do it do it do it.............
For the Kodi remote I have always just used the HDMI-CEC support of my TV. Most TVs support it and it means one less remote and Pi USB adapter. Also as already mentioned using a phone/tablet with Yatse also works well.
Raspberry Pi creator Eben Upton told the BBC the glitch was an "unintentional educational bonus".![]()
Am I just best installing openelec on its own SD card using noobs, then have a separate card for raspian ? :/
Bigbud, I'll write a quick guide tonight on how to install OpenElec on it's own SD card if you like.
Without noobs etc, just need a working Windows PC to do it. (and a card reader)
True but CEC on most remotes has limited control, I simply un-soldered the IR from a faulty xbox 360 mobo (they can also be bought from the bay for £1-£2) and then connected to the Pi via the GPIO pins (no usb needed).
The M$ (or fake r6) remote gives you more control within xbmc straight out the box.
(If you are recycling the IR from an old faulty 360 then it needs 5v supply instead of 3.3v (GPIO pin 2 or 4 instead of 3.3v pins 1 or 17))
Something like below is the best way to get a high current 5v supply on the cheap. 5v @ 4Amps combined for £7.99 delivered
http://www.amazon.co.uk/Version-JET...8&qid=1423581482&sr=8-10&keywords=usb+charger
http://forums.overclockers.co.uk/showthread.php?t=18654322 Already a decent on here FYI. Just stop after step 3.
Why didn't I think of that... Just thrown away 2 broken xboxes. I'm guessing most IR receivers will work, like say from an old satellite/dvd/freeview box?
TSOP4838 Vishay Photodiode , IR Receiver , 38Khz
Bought one of these off the bay, should come in a few days will I need to do anything for openelec do you think?
Finally got my MPEG2 license key. I have a DVB-T2/OpenELEC/tvheadend setup going on. Doesn't even stutter in the menus, even with a HD channel playing. Even streams the TV very nicely to my phone when I'm on the bus.![]()
Out of curiosity what USB DVB-T2 dongle are you using? Also does it record the HD Channels o.k?
Cheers![]()
£20
You jammy git, proper bargain.
I tested recording to the micro-sd card and it seemed good. No quality loss or lag.
