VIRB Recorded my commute home last night with the speaker 'lug' removed, will chop part of it with Tuesdays also recorded commute home (speaker 'lug' in place) later tonight for whoever wanted a comparison.
Have you had a chance to compare yourself? Did you notice a difference?
Also noticed I have a ride from earlier in the week which hasn't uploaded to Strava/Garmin connect and won't Sync, what's the easiest way around this - get hold of the .gpx and import it manually?![]()
Yep, do it manually. Plug the Garmin in and manually go the the Garmin site and upload it. It sounds like you have your Garmin Connect linked to your Strava so it should automatically sync across. If not, then manually go the the Strava site.
It works ok 80% of the time... The 810 regularly (50%) reports 'Upload Failed' even when it has sync ok. But this one ride is being stubborn, other failures usually appeared on Strava 20 mins later
... Not intending on keeping everything anyway
