I had quite a lot of issues with games. They run fine, but play them for 10 minutes or more and they start crashing. That was mostly steam based games, so I had to switch back to 8!
Will probably switch to 10 again once they sort stability out.
Earth[Tera].bin;27615185 said:calc run command works for me, and overall quite enjoying Windows 10 so far.
Even when i run calc.exe from the windows folder itself, it tells me i have nothing that can open calculator.![]()
It will more than likely be a key-verified system like the jump from Windows 7 to Windows 8 for £15 was.
Microsoft are stupid, and make dumb decisions all the time, but they aren't going to do anything as thick as forcing people to roll back to Windows 8.1/8/7/XP if they need to reinstall after a year, they have enough trouble as it is getting people to adopt their new software.
Or you just use a place holder key, install win8.1 from an ISO and then once you are in, then change the serial key to your upgrade and activate.
How are people still nit doing this.
That has not worked for me im afraid, it dose accep initially, but a day or so later i get a message saying invalid key to that affect, last time must be about a year ago, so cant remember word for word, When going through for microsoft support they tell me its wont work at their end either, which is pointless, cause i can do that myself, then sometime they get me through to that system with the verification code, i go through all that and then it does not accept. Iv got the receipts from microsoft, the emails with the codes all allthentic and from them, but at the end they just cant help. or give me a new key. So i thought sod it, ill go back to windows 7 and stay there, but got the itch one bored day to upgrade again when i felt less demoralised and they keys accepted for W8, then i thought ill try my luck and the next key worked for W8.1 and no messages saying key invalid. So the only way to get those keys to work is to roll back to the first OS and keep overwritting it with every version.
This method won't activate for me either. Mine is Pro with the Media Center addon key and it has never worked for me. The free automated service activates it fine though.
Done it loads of times on standard 8 though.
I can't for the life of me get my legitimate 8 upgrade key to work in a direct 8.1 install - highly annoying.
