14 Feb 2015 at 18:50 #21 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 9,440 you can also see it in disk management i am also running windows 10 build 9926 Last edited: 14 Feb 2015
14 Feb 2015 at 18:57 #22 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 9,440 are you able to press the clear OP button and then set OP button again after? it should remove and then re create it
14 Feb 2015 at 20:44 #23 maklabouhlel maklabouhlel Associate OP Joined 26 Nov 2009 Posts 1,241 ED209 said: are you able to press the clear OP button and then set OP button again after? it should remove and then re create it Click to expand... I did that but it asked for defrag to be turned back on before it would recreate it. This is my fourth Samsung SSD and I've never seen this before.
