- 25 Nov 2011
- The KOP
Mantle on thief has always been superb never once had an issue with it.. I'll get some crossfire footage recorded later..
Has a fix been found to correct the inability to use eyefinity with the latest Omega driver? AMDMatt?
Yea anyone know or have an idea when the next part of the Omega drivers ETA will be?
Quote: "Resolved issues: [406493] Displays that go in to sleep mode intermittently causes the display to not wake up"
Has it really been fixed? I've just built a system with the A10 7700k with the latest drivers and the display will not wake up from sleep.
I don't think it's been properly fixed, no. Someone posted problems with waking up a while ago, and I noticed myself once (so I turned off display standby).
Any ETA on driver for dying light or any tips to get it running better?
Even after the new patch Its still doesn't use anything on my system to 100% so so assuming there is a problem somewhere.
I've packed my 970s up to send back and went back to my 290 and GPU usage is showing 100% and temp up to 73c with fans hitting 93% :|
Are you using a reference card?
I can't give you an exact date Finners, but it's coming soon. I've seen Dying Light on the new driver and QuadFire was working well. As soon as it's ready, I'll post about it here.
Hi Matt, I recently got 290x 8gb in crossfire and something id definitely wrong. I tested tomb raider on ultimate and got this..
Then, I benchmarked Hitman Absolution and the game just ran nicely and suddenly hitched down to 8fps..
The GPU usage during this benchmark was quite low and all over the place like (20-30%_ at times on both cards.
Now, the screen just went black, everything on the desktop was a stutter, and this happened..
Disabled crossfire and I get better performance, what the heck?
What PSU, CPU, drivers and resolution are you using?
