Single 980 for 50 - 60 fps max settings at 1440 in most modern games but sli will see you max everything and be over 100fps, no issues with sli apart from some games not supporting it but that usually gets fixed at some point
I've contacted KFA2 to see if they'd send a new fan kit out for replacement, if not the card will go back this week...
Gutted![]()
I wouldn't even risk trying to replace it myself on a card a few days old.
Hi There,
Please return it to the main retailer as it sound like it has taken a knock to it in manufacturing.
So you can get a working replacement asap J
KFA2 European Support
Mines got to go back, not happy
Has anyone used the Gigabyte Windforce 980 GTX? ( Not the G1 )
Agreed. It's mainly the future proofing that's an issue for me. 4gb just isn't enough.
I've just bought one, but not sure whether to use it, or send back and get an asus reference card instead.
Dx12 is supposed to allow vram stacking hopefully that will turn out to be true
hers my score,
think im 1506 core no voltage increase as adding any causes crash.
Gutted![]()
Neil, have you tried removing the card from the slot and making sure the fan isn't clipping anything to make the ticking sound your hearing?
If it isn't coming in contact with anything try either tightening the screws that hold the fan in place or slackening them off slightly.
It's probably due to an uneven amount of pressure. I wouldn't go RMA'ing the card until you've tried this.
Typical.
In all day and DPD wants to deliver my water block between 17:21-18:21.
Was hoping to have it all sorted by now!
Oh well not long to go then I can start to overclock this puppy.
Still well chuffed at the speed of this card at stock playing BF4 on Ultra 2xAA 1440p.
Glad I did not go sli as you really dont need it.
This will serve me fine until the 980Ti/390X comes out.
I take it you bought the EK full cover block and associated back plate?
YOUR BASKET
1 x EK Water Blocks EK-FC980 GTX WF3 - Acetal+Nickel £84.95
1 x EK Water Blocks EK-FC980 GTX WF3 Backplate - Black £22.49
Total : £117.04 (includes shipping : £8.00).
YOUR BASKET
Yep.
minus the shipping fee.
Same as me - works well. Must admit I sweated a bit fitting it, as it was the first time I had fitted a water block to a graphics card, but all ok
Mark
Mark
Hi, thanks for your response...
I have a windows case too & its beside me on the besk.
Looks are a bonus but not a necessity.
Performance is key I guess as my 1440p oc (to 90hz) hazro needs some extra power to achieve the frames in fps games ! A long warranty is also a need in case an issues & helps sell on.
I would like a back plate as I find without the GPU will sag, that's the only thing letting down the MSI...
Does the Strix logo light up ? I read the review & they state it does not but it seems to glow in your photo... A lighting up logo isn't high on my list but as I won't look into my cade while gaming...
