Just started playing fia 15 properly. question regarding.. passing, it seems terrible for me, i play a pass it takes ages to arrive to its destination, even if i move receiving player towards the ball.. by then its closed down and snuffed out!Is there a trick to it?
Holding LT / L2 when you're receiving the ball generally helps as you'll get a closer touch when it eventually gets there.
Passing speed can be extremely annoying and particularly if momentum (or whatever you want to call it) is against you then often the safest pass in the world will be massively underhit and your opponent will be gifted a goal anyway because lolEA. This is particularly prevalent 85 minutes and onwards.
edit: as a general point, what on earth is the dealio with through balls this year? I have mentioned it before but how long you hold the button seems utterly irrelevant to the ball; half the time they will ping it miles away when you've just tapped it anyway.
