Headphone wire length reduction
24 Dec 2011
What is the best way of reducing my headphone wire length? Cutting and soldering on a new jack or removing the whole cable from the cans and installing a new/better cable.
There Panasonic HTF600's for the record and come with about 10ft of cable. I only need around.. 3.5ft or so
Probably better off getting a short cable and swapping them out, that way if you want a longer one again, you've got one to hand. As it will require soldering no matter which way you go, there is nothing in it difficulty wise.
On the thoughts of a shorter cable.. If i did that and made the original cable into an extension for it what quality loss is there for doing this
