Very happy with my Pi2. The interface is almost as sleek as my Intel Core2Duo install.
It's now very usable, whereas before it was just quick enough for the GUI to be not-unbearably slow![]()
Once I have time to sit down and tinker properly it's onto the project... trying to splice together Kodi, Limelight and possibly RetroPie into a single seamless system
I've been reading up on this a little today... it seems like OpenELEC isn't (ironically) anywhere near as "Open" as the name might lead you to believe... I don't think I'm going to have an easy time trying to use it as a base for the above idea... It seems like either raspbmc (OSMC now?) or Xbian will be a better starting point - anybody got any idea which of these is in a better state as I haven't used Xbian before and rasbmc since ages ago (I switched to OpenELEC as raspbmc at the time seemed very bloated)
Does anyone from here have a comparison between the RASPBERRY PI 2 MODEL B and Odroid (C1) alternatives? I'm looking at setting up a small multmedia center with openlec, the Odroid alternatives seem to be a lot more powerful than Raspberry Pi.
I've been using this board for the last month as a small headless server (running Docker containers for rsync backup, web servers, etc, on Arch Linux) and it's been a brilliant bit of kit. Yes, there are teething problems to be sorted out, there always are - remember what the Raspberry Pi used to be like in the early days? UHS-1 can be fickle. My Sandisk SD card works great in UHS-1 mode when powered up, but logs CRC problems after a reboot, so for now I halt + power cycle instead. Without a doubt this wrinkle will get ironed out over time. I've also got a Raspberry Pi 2. The C1 is clearly faster in real use, not just in the benchmarks. It's not hard to see why. Faster CPUs, faster memory, better storage options (UHS-1, eMMC), better I/O architecture (Ethernet, USB and USB OTG are independent buses; they all work off the one USB bus on the Pi), gigabit Ethernet: it all adds up. The Pi is more mature and has a larger ecosystem. The C1 has the better hardware. Take your pick.
Taken directly from the review on the only UK stockists of the ODRIOD.
