The chain and cassette wear at different rates so they will never be "worn together"?
Over the lifetime of a cassette you will probably have replaced the chain 4ish times.
First commute this year with sunglasses. Ah, some vitamin D![]()
Never go out on the bike without them regardless of the time of year
Yes exactly. So if I put my brand new chain (300 mi ish) onto my turbo wheel's cassette (3000 ish miles), its going to skip. Id have to get a new Cassette.
"Worn together" was probably not the best term to use.
What I'm getting at is that it removes all the potential palava with mixing and matching wheels from different bikes/with different cassettes.
This is an excellent idea: http://www.cyclingweekly.co.uk/news...anging-freehub-design-ever-make-market-157363
Still a bit chomping at the bit a little as I can't do any gym work and have to take it easy. Far better than just sitting around though.
Sunglasses? You mean fly deflectors!Never go out on the bike without them regardless of the time of year
Turbo sweet spot?
oh yes please.This is an excellent idea: http://www.cyclingweekly.co.uk/news...anging-freehub-design-ever-make-market-157363
The fathing around it would save would be great! The main one for me would be not having to worry about mixing and matching partially worn cassettes and chains.
At the moment, using any of my bikes with the turbo wheel causes it to skip gears badly as the chains and cassette have not worn together. Yeah, I can buy a new cassette, but it may still skip, and then 6 months down the line when I want to use the turbo again they will be unevenly worn again.
But this would solve all that. Sounds promising.
I've no idea what the Railway path is like and there is only a short section on the busy A4. Has a bit of a climb on it too (Kelston Hill, ooops!)![]()
Kelston Hill is on my commute (if I man up and go the hilly way!). It's a cheeky little climb on a generally quiet A road - steep to start, eases off then a little false flat through the village before it steepens again when it goes left up to the summit.
(although I'm always moaning about needing to ride more hills and have a cheeky small one on my commute I should include!)Winter needs to **** off. I've been ill for the last few days with cold/flu symptoms. Felt it coming on last week and noticed a drop in performance. (I gave up on a Sufferfest after the 5min warm-up!)
Right now, any cycling induces a severe coughing fit.![]()
What glasses are you all wearing? I've had the same pair of DHB's since July and I wear them every ride (replaceable lenses) any weather! The clear lenses are getting a few scratches though so I may track some more down before autumn this year. Most sunglasses I find have too much rim on the outside edges to use for commuting - you need good behind visibility from a shoulder glance.
You are right, the cold didn't cause it but the cold air passing through my lungs is certainly exacerbating the cough!
