- 22 Oct 2012
- The Moon
Switch the bios back then.
I wonder if perhaps you can test each card on it's own for a day or so to see if either card gives you problems. Please also ensure your whole system is at stock.
Idle problems usually indicate something is unstable somewhere if the systems works fine under 3d load, just need to try and find out what it is.
I also find it odd that disabling ULPS locked your system up.
Yep, I'll try each card for one day and see if I experience any issues. It's very confusing since my old 970 sli setup has 0 freezing, but these cards seem to perform really well in games. It's just the random freezing on black screen when loading a program.
I've contacted Gigabyte asking if they have any idea, perhaps there's an issue with the PCI-E slot.
