Hi there
I was all set for pulling the trigger on F1AS2's for the M3 as in my size MPSS is not available but Jon from tyre reviews messaged me F1AS2 has gone through revision changes in some sizes which has made them feel numb and cause strange road noise.
As such I decided to be guinea pig and actually try the New Yokohama Advan Sport V105 97Y XL all round, changing from cups and from Continental M3's. Also noticed they are 240 tread wear!
First thing I noticed and worried me was how stiff the sidewalls was, the car on cups was rather crash on the road unless a red hot day where the rubber was softer so this made me expect back breaking ride with the V105's as the sidewalls far stiffer than cups, surprising for a road tyre.
I've done less than 100 miles, first 5 miles was just wheelspin due to release agent on tyres, once gone however where the cups would spin up in 2nd even in the dry these Advans can pretty much handle all the power even in 1st so that is very welcomed.
The surprising part ride quality, much better than cups so sidewall stiffness does not necessarily mean a crazy ride, not quite as good as the Continentals but close which for a lower profile tyre is good.
I've not pushed so much in dry, but in the wet they are as per reviews say, huge amounts of grip and fantastic levels of feedback they seem very progressive and allow good throttle application out of corners in the wet. They could be good on track in the wet for sure.
So far so good, once done a few hundred miles and driven them on a mixture of roads I shall report back.
