Ouch! Take it easy for a few days man, you'll heal! Get the bike looked at if you can't sort it yourself, by the mechanism I assume you mean the shifter and not the rear derailleur/pulley?![]()
Ok, bike builders. I've got all the bits for my single speed build, apart from the brake levers which are due in the next few days. What's the deal with fork cutting/sizing? As near as I can tell the fork has 30cm of steerer, the frame has a head tube of just over 10cm and the headset has a stack height of about 3cm. So do I assemble it with the uncut steerer and then ride up and down the street with 17cm of head impaling steerer poking out of the top until I'm happy with the fit and then disassemble it again and cut it when I'm sure I've got it right?
Yes. Assemble, set it to the height you want, ride it for a bit to make sure it's right.
Dont cut it flush with the top of the stem, you need 2-3mm so that the top cap gets pressed against the stem and doesnt touch the steerer.
15% is hard no matter the gearing. A 30t is enough. Yes, you could go to a 32t, but it wouldn't make things appreciably easier.
I've climbed everything I've climbed on a 28t, and that includes a few 25% stretches![]()
You can get 25mm versions of all the P4 range of tyres, aside from the SC Grip. Moving to 25mm is definitely worthwhile but it won't improve your grip on mud or leaves (or ice, or snow) - if you want grip on those you'll need to move to much thicker tyres with deep treads (or metal spikes for ice). Obviously not an ideal thing to do with a road bike
I'm not saying to not get the 4 Seasons. They're good tyres. Just make sure you're getting them for the right (4)reasons.
edit: An 11-28 cassette would've made the climb harder. More teeth on your back cog = 'easier' gearing. Opposite to your front cogs.
New saddle and bars.![]()
Yeah but you're a machine, almost as bad as those blokes from down south, or the Tart, with their miles and average speeds!
I guess now I'm getting more and more serious about conquering these hills/rides I really shouldn't go changing my bike and setup. At the end of the day I've got a good bike for it (light & range of gears) it's just the rider which is holding it back!
I had a dimebar moment about cassettes too don't worry lol
Good point about the 4S, I guess I'm just looking for an alternative to the P4SC & Grip (ie a 25mm version) as they're never in stock/listed on Wiggle... Than again the 4S are currently out of stock too lol![]()
*requests to follow*
I haven't been able to cycle in over three weeks. It's really bothering me now, I feel so lumpen and unhealthy. Not being able to run really hasn't helped matters. I am tempted to get a new bike once I have recovered...
I like to think I'm doing everyone a favour by not inflicting another black Dolan on the velodrome!That looks way too manly for a fellow Mancunian
That's not the same bike you took up Swiss Hill, right?![]()
I see Froome is still struggling to keep the pace with Contador this year. Finish 19 seconds behind him on todays stage. Both seem a band apart from the rest but Froomey isn't quite able to pip him.
Thanks Shamrock and Von - I try my best.I like to think I'm doing everyone a favour by not inflicting another black Dolan on the velodrome!
