So my motherboard even though it doesn't seem to support my CPU and from
Marine's comment
''The 9590 have a TDP rating of 220W, but your motherboard spec only listed as Supports CPU up to 140 W" and only with "6 +2 Phase Power"...this could be the problem.''
My issue is 100% overheating?
EDIT: that comment seems to come across a bit rude, sorry. I just want to be sure, because I got be going back an forth like a yoyo and it will cost money every time I change something. I appreciate everyone's input, I would rather it be overheating. Could you recommend me a GOOD cooler for my CPU?
I'd imagine if the Corsair AIO is seated correctly, PWM fan running correctly, pump working correctly it is more than capable as I'd imagine it will be much much better than the stock cooler that chip would be sent out with?
