Can anyone recommend a touch screen for the Raspberry Pi 2 plus a case to fit it all in ?
What size you looking for.
I'm after a 7 inch buy for an Original Pi and all I can find is one from Hong Kong
Hi again guys,
Just used http://sourceforge.net/projects/win32diskimager/?source=typ_redirect this to "read" OSMC to a new 16GB SD card
But still getting solid green + red lights
Any ideas?
Have you tried the OSMC installer
https://osmc.tv/download/windows/
Download
Pop in SD Card
Follow prompts and it'll download and install the correct image
Download
Pop in SD Card
Cheers, has worked apart from apparently it only is a 239mb SD card now when it should be 16GB?
That's normal, you'll have that fat partition then the rest is a ext4 partition that windows can't see
Just taken my micro-sd card out of my Pi as I want to use it with my phone again. Plugged it in my PC and tried formatting it but its only showing as 814mb not the 32gb it is.
How do I fix this?
EDIT: Got it all working now!
Try thisFrom this - I can't get past step 5 as it says "tail: cannot open 'blah blah'
tail: no files remaining"
http://forum.osmc.tv/showthread.php?tid=6978
Trying to remap the remote buttons as the return/back button isn't working for me? Anyone got some help/links?
Cheers
watch -n 1 tail -n 20 ~/.kodi/temp/kodi.log
