You can buy it in the supermarket or shoot your own.
Pretenderized meat from being smashed by a car or truck no thanks! Would have only been there a few hours in this case but I'd rather not!
Suprised everyone missed this... But 'Bergers Roo Burgers' has a ring to it!
The Rusty Bucket!
Well worn teeth on the second cog!
Doesn't look that bad to me, you may find a damn good scrub just how pristine a rusted chain can look! Teeth don't look that bad to me either as you said you'd done around 1000km and never cleaned it?! Looks very dry too... When did you last lube?
Ok set and price, but if you have a brush to use pickup a chain cleaner (cheaper than buying brushes for the hell of it) and
some degreaser for using in the chain cleaner... Other people use lots of different things, some even use their own degreasers (WD40!
general consensus is if you're using it to degrease you should also grease/lube with it after every ride) and cleaning products (washing up liquid - careful it contains salt, causes rust!).
@Derek W - I can't believe that chainset is £20. That's utterly ridiculously low amounts of money for a chainset.
Yup great price, but as Perma said:
You almost certainly won't need to replace your crankset. And those B'twin components aren't great for the price. It's a good opportunity to upgrade. I'd suggest something like this:
You can upgrade the chain and cassette for around the same money!
GIEF!
None of the pro4 E's, SC's or SC Grip's now listed on Wiggle in 25mm
Ride in to work this morning I felt strong after a rest day yesterday, did a semi 100 cadence drill on the latter slightly uphill part and got a great average speed - 16.5 mph.
Ride home this evening I still felt strong and there must have been a little tail wind. Cooler than earlier so I went 'TT mode' on a piece of my commute that is usually clogged with traffic (was clear) and has a nice fresh tarmac'd surface. Raced/left behind MTB redlight jumper who was an ass (I'm stopped at a cross roads waiting for a light change, he pulls up in front of me, blocking me) and another great average speed - 16.4mph.
Ride home took 15 mins - around the same time it takes me on a good day in the car. Result!
