Man of Honour
- 16 May 2005
- Manchester
No thats on a P2M, yeah, will see how they go in a race this weekend, if they're ok can't see myself going back to 23's. Want to try latex tubes as well, see if there is anything to gain there.
Ah, fair enough
Latex tubes are on my list for my new bike. I'm also going full-on gimmick and trying these: http://veloplug.com/ May as well bling it up
The thought with the crankset is because a couple of the teeth on the middle cog were a bit worn and as FrenchTart says, its only 20quid! I'll check out the alternatives too. Thanks![]()
It's quite possible given the cheapness and lack of maintenance that the teeth on your front cogs have worn at a much faster rate than any of us would expect with our experiences of slightly higher-end parts. The main thing though, as you say, is that it's £20. So...may as well
Suprised everyone missed this... But 'Bergers Roo Burgers' has a ring to it!![]()
Lolz
GIEF!
None of the pro4 E's, SC's or SC Grip's now listed on Wiggle in 25mm![]()
To be honest CRC is the go-to place for these. There's another UK store that is slightly cheaper but CRC is often my next choice after trying Wiggle.
Ride in to work this morning I felt strong after a rest day yesterday, did a semi 100 cadence drill on the latter slightly uphill part and got a great average speed - 16.5 mph.
Ride home this evening I still felt strong and there must have been a little tail wind. Cooler than earlier so I went 'TT mode' on a piece of my commute that is usually clogged with traffic (was clear) and has a nice fresh tarmac'd surface. Raced/left behind MTB redlight jumper who was an ass (I'm stopped at a cross roads waiting for a light change, he pulls up in front of me, blocking me) and another great average speed - 16.4mph.
Ride home took 15 mins - around the same time it takes me on a good day in the car. Result!![]()
Sounds like you're still making strides with your speeds. It's not all down to tail winds and probably a good portion of it is you not having as much confidence in your own abilities as you should. I often find that I think there's no way I can maintain a speed until someone annoys me by RLJing and I find myself chasing them down at a far faster speed than I thought I could do comfortably
