CS:GO Discussion
I want this as an in game setting
Yeah I posted some on the page earlier, after I saw them on Reddit. Did 3kliksphillip really have to walk around recording every possible reverse map, when someone had already done it?
Confusing ain't the word, they should reverse DustII say for example for an Aprils fool. :)
Whats the next move then Joel? Trade it for something like a m9 fade with adds like a howl statrack or fire serpent statrack?
Anyone know how to make the mini map zoom out further? Also put a the first letter of the name on the color marker?
The next move is either getting 380keys and I'll get something cheap or I want a karambit fade 60/40 with 100keys as adds or I want 14 field tested awp Asiimovs.
I'd then sell them for keys.
Trading takes so much time.
I have the radar zoomed in, i think its more useful or quicker to view
Heres the next very profitable trade
2048x2046.resizedimage
1536x2048.resizedimage
8BB70A7940892C3F09E3CF0403546A3AFD959545
http://www.knifecenter.com/item/UC2...nch-Black-Blade-Shoulder-Harness-Kydex-Sheath
How do you activate the console anyway?
Options > Game settings > enable developer console. you can enable it and then the key to view console is listed like any key under options > keyboard
developer 1 = leet stuff
//Radar zoom in-out script
bind "KP_plus" "incrementvar cl_radar_scale 0.25 1.0 0.05";
bind "KP_minus" "incrementvar cl_radar_scale 0.25 1.0 -0.05";
http://www.tobyscs.com/csgo-radar-settings/
C:\Program Files (x86)\Steam\SteamApps\common\Counter-Strike Global Offensive\csgo\cfg is where your config and autoexec are (if you have one).
Just CTRL+F and search for radar in ur config and replace what is needed or use it in the autoexec
It can be tricky zoomed out in deathmatch or casual, with the multiple players I tend to have more trouble finding my position on radar. I have got used to it and would miss not having full map radar now.
deicided to have a little bet today due to my recent luck
3dMax were favourites but only a 69% on csgol
I bet my MW vulcan & BS AWP Asiimov
won another MW Vulcan :)
I couldn't disagree more. Being able to see bomb/enemy locations/teammate locations from a single quick glance and wherever you are on the map is infinitely more useful imo.
Yeah I mainly wanted it so that when a bomb gets downed I can tell straight away wgere it is instead of just knowing the direction of where it is, same as when enemies are spotted.
Think there is a saying that fits well here
The rich get richer whilst the poor get poorer!
