Windows 7 Disc Install With No DVD Drive
17 May 2012
I'm going to start building my new PC today. I have a legitimate copy of Windows 7 OEM, but I don't have a CD/DVD drive for my new system. Is there any way I can take Windows 7 off the disc and put it on a USB stick to install it on my new system that way?
My preferred method,
Run Command Prompt as Admin
diskpart
List disk
Select disk ? ( make sure to select your USB drive )
Clean
Create partition primary
Select partition 1
Format quick fs=fat32
Active
Assign
Exit
Exit out off command prompt
Simply copy the Windows image files to the USB and boot from USB.
I'm using a laptop at the moment. Could I not just install Windows 7 on a HDD somehow and just plug that into my new machine or plug this HDD into my machine?
Download your preferred image then check and compare the SHA1 with the same file available from MSDN
Code:
https://msdn.microsoft.com/en-us/subscriptions/downloads/hh442898.aspx#searchTerm=&ProductFamilyId=350&Languages=en&PageSize=10&PageIndex=0&FileId=0
If the codes are the same the image will be safe.
Code:
I don't understand what that means lol
SHA1 generates a checksum based on the contents on the file. It's a way of proving the file has not been tampered with.
If you don't understand that substitute "Magic number".
Obligatory LOL.
Ok.
Well I chose Windows 7 ult SP1 x64
File Name: en_windows_7_ultimate_with_sp1_x64_dvd_u_677332.iso
SHA1: 36AE90DEFBAD9D9539E649B193AE573B77A71C83
If this was your chosen image once you have downloaded it and before you did owt with the image you would download a SHA1 checker.
Once your chosen image has been run through the checker it will produce a SHA1 number.
This should match the one made by Microsoft.
If the numbers are exactly the same it means the image as not been altered, which would mean it's safe.
If they do not match it means somebody has altered the image, which is bad and so not to be used.
Does this help.
Tell you what tell us your preferred Windows 7 version.
From the link in the earlier post.
I will download it and check the hashes.
If they match I will let you know.
Then you can download it yourself knowing its safe to use.
Ok.
Does this help.
I'm downloading a SHA checker now. However, I chose the;
en_windows_7_home_premium_with_sp1_x64_dvd_u_676549.iso
That's fine, what ever your choice, is fine.
On MSDN
https://msdn.microsoft.com/en-us/su...Languages=en&PageSize=10&PageIndex=1&FileId=0
Windows 7 Home Premium with Service Pack 1 (x64) - DVD (English)
File Name: en_windows_7_home_premium_with_sp1_x64_dvd_u_676549.iso
SHA1: 6C9058389C1E2E5122B7C933275F963EDF1C07B9
Just check that against your downloaded .iso image.
If they match well you are good to go.
If they do not match simply delete the image and source again.
I thought I would test this download link myself, just for a laugh. Gunn take a while though. 1 hour 17 mins exactly.... Tooooo slowww.
I've got a Windows 7 Home Premium (X64) disc. It's OEM, but it's genuine Microsoft. Is there anyway I can just use this instead of downloading different Iso's?
yes you could. if you bothered to read my previous post, i provided a link to the software that does it. :p
