Caporegime
- 8 Jul 2003
- In a house
Thats normal at idle i think, power saving feature, 2nd GPU shuts off.
I tried what you told me to but that didnt work, i just opened my case up and noticed the fans on the second gpu arent even spinning, im going to take it out to check if theirs a wire that came off somewhere
or is this a software problem
Only just started so I'll let you know.
I've just discovered the Dying Light manager which allows you to tweak settings so I'm currently playing with that and trying to turn off all the horrid image blurring that this game suffers from. Hurts my eyes!
I love Dead Island though, so I'll expect I'll like this.
yeh it could have done with a ton of more ingame options that actually did something lol i liked a lot of how far i played yeh
the side missions i didnt find totally boring and the crafting system better than farcry4 for sure! i played it mostly co-op so didnt get long into the story yet
there's been atleast 1 update since i tried it last so wondering if it plays any better
been getting into HOTS a bit more so my free time has gone there![]()
If the computer is in 2D mode this is normal if you have ULPS enabled, the second gpu literally turns itself off including the fans.
Disable ULPS in afterburner restart and the fans will start spinning, slowly at idle.
that sorted that problem -) i can control my fans now, if i have upls enabled will my customer fan profile kick in during gaming?
Tomb raider wont allow me to run exclusive full screen as it says problem initiating dx11 in current system config, however i had that before so its not gpu related
Crysis 3 ran flawlessly though (i can max it out on 1440p with 8x msaa and still get playable frames) and im going to test your fc4 profile out soon
Thanks for your assistance
I know you will like this.![]()
Wanna hope that these drivers are in a better state than they were about a week ago![]()
Dying light does not appear to be very demanding at all I've noticed.
Think i need to invest in a 4k monitor
Which one do you all use and are they any good?
Is that UHD?
What sort of VRAM usage are you getting? Is this another game for the 8GB cards at UHD/4K?
I want to buy Dying Light but won't until i hear it runs well on AMD, all i here its preety bad on these cards
Works well for me.
What resolution and what card will you be using? It seems 1080P/1440P 1>2 cards works perfectly without a driver update for me.![]()
Hi Matt MSI 290x at 1080p but i hear a lot of people having bad framerates on AMD cards if you look at steam reviews etc
Maybe the new drivers will help
