- 29 Dec 2004
- Shepley
If they're same as Racing 7s they'll use sealed bearings and grease will be little help. You'll need new wheel bearings which aren't expensive but a faff to fit.
^ You have posted the same Strava link twice
Wow, that's rather more dramatic than you might have been hoping for. Shame that had to mar the ride.
Yeah. Ah well
I forgot to mention but my Garmin went crazy with the navigation too so we ended up doing a completely weird route (I think). Still saw the nice bits (and those were really nice) so I guess it doesn't matter too much though.
Looks like you went the wrong way round! I'm sure it looked good either way.
Nice. Is it just clear lacquered steel then?
Mine is still all in its boxes waiting for me. I think I might take a day off the week after this one and spend the day putting it together.
Garmin Virb mounts, who's using what?
FrenchTart said:I guess if you're already used to the plastic Kendas you're less likely to have this issue though. I don't want to sound like I'm pressuring you (though I totally am) but you could potentially save money by getting them to build the bike for you with better tyres - they will often offset the cost of the upgrade against the money they save by not building in the other tyres.
I was wondering where was the best place to get a Garmin mount from for my Edge 200? Pretty tapped out after getting the new bike so cheap is goodand I'm thinking the "out front" type ones might be my best bet?
Quite disappointed with the hubs on the Fulcrum Racing 5s. Actually, they're atrocious. I've only been using them this winter, washing the bike down after every ride. Today I noticed that the front hub is not spinning freely at all. Thought they were bombproof..
To top it all off, the guy riding with me had an issue with his brakes and crashed into the side/back of me.
Kendas can be a bit hit and miss, some pro riders swear by them, yet some really cheap bikes come with them too. They're either very situational or have such a wide range that nobody quite knows what they're riding until they win/taste tarmac.
You can't lump a whole brand into one like that, take continental, gatorskins are awful and GP4000s are one of the most popular tyres around
PlanetX code - Ukdl20
Have fun![]()
Details?
My rigid vittoria rubinos cost like £7 each. Wish me luck!
