- 17 Sep 2006
- Gloucestershire
Summer bike out this morning. Still very cold winds, but other than that, it look like we're in for some nicer weather for a while.
The 5800 really us fantastic, altho disappointingly I need
to adjust the limit screw on front derailleur. Will be sending Evans an email for feedback. Shouldn't be leaving the workshop with such simple issues.
What's your budget? It's not a great bike, but it's certainly not terrible.
I do wish they'd get their details right... The specs say it has v-brakes, the description refers to dual pivot brakes, and the image shows cantis!
As Von said, it's not great. If you can let us know your budget we can make suggestions.
Can you get any kind of bike2work scheme? That can help up the budget and pay towards helmet and other bits you'll need.
If you post a rough start and end point some of us may be able to suggest routes too![]()
Well...as interesting as turbo work gets without a video![]()
It's my birthday today, and my grandma has very kindly sent me a cheque which will cover the cost of some bits of Torm clothing. My parents are also promising cash which will be going on some proper road shoes. Good times.
Indeed. Nine Hammers is great for interval induced pain.
That does look like fun. I've done a fair bit of Sufferfest and certainly found things like Revolver super painful. :/
Thankfully it's not in the plan I'm following (http://www.trainerroad.com/cycling/plans/152-short-power-build-mid-volume) but I'm sure some of those other sessions will be similarly hellish.It's my birthday today, and my grandma has very kindly sent me a cheque which will cover the cost of some bits of Torm clothing. My parents are also promising cash which will be going on some proper road shoes. Good times.
You do own the bike eventually - I wouldn't let that put you off. I've used the cycle2work scheme at my place 3 times without issue.
Personally I wouldn't make your first bike a self-built one but that's just me. There's a lot to learn when you first start up and having an LBS to offer free services/advice can be helpful.
How is the surface on the canal path? I'd probably discount it as an option if it's anything less than decent tarmac.
Also, definitely get drop handlebars. I got a hybrid with flat bars for my first bike and regretted it. In fact, the previous thread was filled with people that got flat bar bikes and regretted it/bought drop bar after. Sounds like you're already open to the idea of trying them out and getting used to them so I guess my point here is more "do it - you won't regret it"
Might have more useful suggestions later when I get a quiet moment in work.
I get my bearings from a local supplier. usually better bearings for less money.
