Which onedid you get? There are loads of different ones
I bit the bullet today after being underwhelmed by the M9 and S6, and ordered a Note 4 in black. Should be here tomorrow
Did anyone find a good car charger for it?
Thanks.
Thanks.
Ps, does the fast charge facility cause any damage to the battery?
I get that in kitkat on my note 3 - dont think its a lolipop only "feature"
What tint is this?
Sligh pinkish hue on white backgrounds...
are mobile phones direct any good?
Was also looking at that, not sure if its safe. For one, they don't tell you the Note 4 Number.
Is it a SM-N910F Note 4 Snapdragon European variant? Or is it sourced from overseas?. I'm thinking it might probably be the Note 4 SM-N910C Exynos variant as the technical specs doesn't list it as a CAT 6 or LTE-A which the snapdragon variant has.
