Man of Honour
- 21 Nov 2004
So I installed a 295x2 today along with the new Benq monitor. Seemed to work ok with a hdmi to mini DisplayPort cable. Switched to a DisplayPort to Mini DisplayPort cable and now when it is plugged in I can't turn the computer on with the power button or bring it out of sleep. Only thing that works is if I clear the cmos, take out the dp cable, then start it up and put the dp cable back in. Motherboard is a z87 d3hp. What on earth is going on?
I will try setting the default bios and check that on board graphics are disabled. Not sure what else to do!
Edit: that didn't work
