- 6 Jun 2009
- No Mans Land
Well your cpu ring voltage is well low, pump that sucka up to 1.3v.
That will be good for 3.5Ghz easy for your uncore speed too.
You could try and lower your cpu voltage to 1.3 (maybe even lower) when you've upped cpu ring voltage to 1.3v.
As for your SA voltage that's pretty low (compared to me anyway) but then again you only run your ram at 2400mhz (I think) so that's pretty easy on the system so probably don't need much like your running. I run my ram at its rated 3000mhz but my SA voltage needs +400. I've seen many other gigabyte overclock guides and all runnig 3000mhz + on the memory the SA voltage gets quite a boost from stock like I'm runnig so it's nothing out of the ordinary. Bare in mind this is for gigabyte boards only I'm talking, Anus boards the voltage could be quite different.
Playing around with more could help with stability too (if upping the cpu ring don't work).
Hope this helps buddy.
