Had this phone for 2 days now, mind blown, enough said.
Had mine since launch, still impressed with it, just waiting for the lollypop update now.
Same here and the S6 launch hasn't done anything to change how I feel about it. The Note 5 will probably change that.
Good deal at mobilephonesdirect -
Note 4 - £29.99 (£30 Quidco cashback)
£26.99 a month (EE 24 Months)
Unlimited Calls
Unlimited Texts
2GB Data
Whats the deal with the mobile industry moving away from SD slots? I know they are generally giving us higher onboard memory, but I love having SD slot, would be even better if i had and externally accessible slot, I quite often swap between cards when i'm away from home, surely its not that huge of an ask to have both high capacity onboard memory and an SD slot.The way things are going the note 5 might not have SD slot or replaceable battery![]()
They are highly unreliable and prone to failure - not really surprising manufacturers are moving away from them. Non removable batteries on the other hand... inexcusable!
Dem profit$$$
Never had an SD Card failure myself.
The are most definitely not!
Many have lifetime warranties, are dust, shock and waterproof. It's pretty much a forgone conclusion that any SD card will outlive the device you're using it in, several times over.
I appreciate many people will "never have had one fail" which is good but a LOT of people do have them fail and its far from a forgone conclusion they will outlive the handset.
in my 5 years of using android phones I've had 3 cards fail on me and its not some freak occurance.
Thats a rather bold statement... any evidence to support this or is it just opinion/hyperbole based on the fact you've not had problems with sdcards?Obviously a lot will fail, so will anything that's sold in large numbers. But as a percentage the amount is tiny, far, far lower than that of pretty much all other (far more complex) electronic products.
Obviously if people are buying bargain basement cards from a random street corner shop then they're going to fail more frequently, but a good quality card is going to last.
Your actual point was that they're highly unreliable, which they simply aren't. They really are far more reliable than the phones they're used in.
